    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. mikenbrenda New Member
    Cadott, WI.
    I was reading that your glass and foul up with soot if the Air Wash system is Clogged up, where exactly is this air wash system on this stove??
    #1
    Helpful Sponsor Ads!
  2. jtakeman Minister of Fire
    Northwestern CT.
    Air wash is at the bottom of the door glass. Open the door(stove off of coarse) and you'll see a tin strip that runs along the bottom. Use something thin to slide in and out.
  3. SmokeyTheBear Minister of Fire
    Standish, ME
    It is a small gap around one side of the glass that allows a small amount of air to be drawn across the back side of the glass keeping combustion byproducts from getting to the glass, ash eventually plugs this small gap up and stops the air flow.
    Usually it is along the bottom edge.
  4. kinsmanstoves Minister of Fire
    If you have a compressor, remove the door by opening it and lifting it up. Take the door outside and hit it with air. If you do this with the stove running have someone video tape the results and post the video.
    Eric
  5. imacman Minister of Fire
    ;lol
    kinsmanstoves likes this.
  6. kinsmanstoves Minister of Fire
    I "likey" your like.
  7. mikenbrenda New Member
    Cadott, WI.
    thanks it's working better already -35 below here so outside will happen later this week, does the strip run all the way thru?? cause we cleaned it best we could from the top with a credit card like card..
