Are there only 2 burn phases - off-gassing and coaling? Also, does anyone have a chart showing heat output over time in each respective phase?
HotCoals said:I hear where there is smoke there is fire but most of the time I can't see the fire..it's usually choked way down and besides my glass is usually to dirty..lol.
All clean here thanks!Battenkiller said:HotCoals said:I hear where there is smoke there is fire but most of the time I can't see the fire..it's usually choked way down and besides my glass is usually to dirty..lol.
Which brings up the third phase of burning...
The chimney fire.
murphyslaw1978 said:Wikipedia does show 3 phases:
Preheating phase, when the unburned fuel is heated up to its flash point and then fire point. Flammable gases start being evolved in a process similar to dry distillation.
Distillation phase or gaseous phase, when the mix of evolved flammable gases with oxygen is ignited. Energy is produced in the form of heat and light. Flames are often visible. Heat transfer from the combustion to the solid maintains the evolution of flammable vapours.
Charcoal phase or solid phase, when the output of flammable gases from the material is too low for persistent presence of flame and the charred fuel does not burn rapidly anymore but just glows and later only smoulders.
HotCoals said:That's quite a order to fill.
Battenkiller said:BB... is that what JG said? I hate to cut and paste, or provide links to technical information. It's much more fun to pretend I figured all this stuff out on my own and didn't get it from some Shelton book. ;-)
BrotherBart said:I was like you in math classes. I wanted to know why, not just accept theorems.
BrotherBart said:http://woodheat.org/index.php?option=com_content&view=article&id=59&Itemid=69
Battenkiller said:HotCoals said:That's quite a order to fill.
This is the best answer so far IMHO.
I was disregarding the charring stage because the OP was concerned with heat output. Pyrolysis is a heat input reaction.
The proportions of gases produced to charcoal produced are burn-rate dependent. Faster burns produce more smoke, slower burns produce more charcoal. Faster burning woods produce more smoke and less charcoal than slower burning woods. Pine leaves fewer coals but makes more smoke compared to black locust. Introducing more air will speed up the burn rate and skew the proportions to the smoke-producing side.
As far at heat output rate, well, smoke burns tons faster than charcoal because it is a gas. Given the exact amount of air for perfect mixing, it will burn as fast as the smoke is introduced. There is a lot more heat in a pound of charcoal, but it takes a long time to burn so the rate of heat produced is low. Unless you're trying to set a low wood consumption record, most of us are concerned with the rate of heat output rather than where the total amount is derived from. I like active flame because it gets the stove hotter, but the wood disappears faster. That's where the higher heat output rate comes from, by burning more wood faster.
Good explanations. I just figured there were some tests done on this. It would be interesting to see the same type of wood used in a multitude of experiments using graduated temperatures and air settings. The variables are still many, but I'm guessing the charts would still be effective at explaining just how much heat can be expected from each of the phases.
In general, a declining fire will produce less and less heat per hour as the internal flue temps drop and draft gets progressively lower in strength, meaning less air is being drawn into the stove. A charcoal forge has a tuyere at the bottom that forces air directly through coal bed. This can be a powerful electric motor, a hand-crank blower, or a great bellows like smiths of yore used. By forcing air through the coals in an artificial manner, higher burn rates of charcoal are possible, and higher heat output is the result. Your stove doesn't work that way, so you are faced with a steadily weakening engine as the flue gets colder and colder. Eventually, things come to a halt. The ashes may provide enough insulation to keep those coals hot for days, but there will be no noticeable heat output from the stove at that point.
DonNC said:I dont know about the phase but once i get a few pieces of really dry wood fully engulfed, I turn the air all the way down and then something cool happens. In short order the wood stops burning but the fire does not go out. It jumps up to the tubes on the ceiling of the stove and stays there. Awesome thing to watch. The stove runs about 560 and stays there when that happens. when it looks like its about to stop I open the air a little until there is a bit of flame at the bottom ...just a little... and then the top picks up again. The book says this is the most efficient setting
Its the really cool looking phase
Warm in RI said:DonNC said:I dont know about the phase but once i get a few pieces of really dry wood fully engulfed, I turn the air all the way down and then something cool happens. In short order the wood stops burning but the fire does not go out. It jumps up to the tubes on the ceiling of the stove and stays there. Awesome thing to watch. The stove runs about 560 and stays there when that happens. when it looks like its about to stop I open the air a little until there is a bit of flame at the bottom ...just a little... and then the top picks up again. The book says this is the most efficient setting
The slpendor of the secondary burn light show. I call it Caveman TV. I never miss an episode.......
DonNC said:Warm in RI said:DonNC said:I dont know about the phase but once i get a few pieces of really dry wood fully engulfed, I turn the air all the way down and then something cool happens. In short order the wood stops burning but the fire does not go out. It jumps up to the tubes on the ceiling of the stove and stays there. Awesome thing to watch. The stove runs about 560 and stays there when that happens. when it looks like its about to stop I open the air a little until there is a bit of flame at the bottom ...just a little... and then the top picks up again. The book says this is the most efficient setting
LOL caveman TV!
I was so amazed by that Im calling my wife into the room to look. She looks...says mm hmm...and goes back...but not me... I cant move away... like the 4th qtr of the Pitt Balt game last weekend. Amazing.
Battenkiller said:Lady BK is a dedicated fire watcher. Every summer night we can, she's got the chiminea stuffed with dry wood. I mix the drinks and grab the cigars while she finishes the dishes, and she just can't wait to go out and strike that match and sit back for the show. If it's buggy, we'll go out to her woman cave (screened-in gazebo) and have a fire in her fire pit there. We'll sit there for hours, mostly in silence, just watching the fire and mentally taking note of how the fire shifts, trying to predict when and where the next good spot to drop a split will open up. Same on our summer camping vacations. It's the highlight of her day, really.
So... I just asked her for her thoughts on secondary displays. An exact quote: "Eh... Well, I think they're pretty cool looking, but it's not something I'd want to sit around and watch or anything."
There goes that bargaining chip out the window. :-S
Warm in RI said:That's an interesting conclusion. I wonder why the different attitude toward secondaries?
Cool that you can sit and watch in silence for so long. Speaks volumes about your marriage.
Of course, I had a marraige like that once, though the silence wasn't comfortable, mutal, or a positive sign. >:-(
