What set-up do you use or what way would you go? Looking at making butterfly joints in slabs and like the idea of using inlays when knots just dont going to work.
fishingpol said:Check out butterfly key joinery on Rockler.com. They have the process posted. It is nice looking when finished.
PapaDave said:smokin, a little off topic, but here's http://creatingsawdust.com/2010/02/how-i-taper-legs/ a guy who does tapered legs the easy way. Not sure if you're into this type of stuff. I just found this a couple months ago. Cool vid.
I've never done any BF joints or inlay work, but looks nice when done right.
smokinjay said:PapaDave said:smokin, a little off topic, but here's http://creatingsawdust.com/2010/02/how-i-taper-legs/ a guy who does tapered legs the easy way. Not sure if you're into this type of stuff. I just found this a couple months ago. Cool vid.
My dad really good at that. I just looking to really dress up checks on small boards. Even Looking at using a hickory butter flys on walnut boards just to make the joint really POP! (old school)
Thistle said:smokin said:PapaDave said:smokin, a little off topic, but here's http://creatingsawdust.com/2010/02/how-i-taper-legs/ a guy who does tapered legs the easy way. Not sure if you're into this type of stuff. I just found this a couple months ago. Cool vid.
Any color contrast like that usually looks awesome.Walnut with Maple,Maple with Cherry or vice versa,Ebony plugs or pins with lighter woods etc. I did a smaller footstool/bench out of 8/4 Honduras Mahogany with Ebony plugs/inlays for parents anniversary about 15yrs back.Last time I seen it,that thing just glowed.
LLigetfa said:I've always known them to be called a dutchman. They are usually meant to be celebrated and so they are supposed to look hand done, often placed counter to the grain.
Adios Pantalones said:I wouldn't use a router at all- I'd go with hand tools. Power tools just help you screw up quicker on detail jobs like that- plus- it's small enough that you're not saving that much effort I'd guess. Maybe a jigsaw.
Adios Pantalones said:Ya, just for the hogging out part. Very satisfying little touch there. make sure to post good pics
fishingpol said:Go with a router, don't rush it, but don't go to the line. Clean up with sharp chisel. If you screw up, you can always make it bigger.
fishingpol said:A little bit of new technology to remove material fast, and a little old school to finish it up. I am not a woodworking purist. Nothing wrong with using power tools when available.
