I bought this coal stove recently. I was told it was a train caboose stove. The only problem I’m having is finding the oval chimney adapter. And was just wondering what would be the best way to get a working chimney. The oval is 3”x 4 3/4”
High quality 4" single wall stove pipe. Comes in (2) lengths: 20″ – 40″. Perfect for safely venting your small wood stove with a 4″ flue outlet. Don’t forget clamps! Every pipe joint needs to be secured with either a clamp or three stovepipe screws. We recommend ordering a pipe clamp along with...
You pour coal from the top through either port the shaker box caches it. Then the vent on the from comes off to scoop the ashes out. I plan on putting a box in to catch the ashes and make clean up easier.
Doesn't look anything like a caboose stove to me because it has no mounting holes in the base and no cook top. It's more than likely a brooder stove, for baby chicks.
It’s possible like I said I was told it was a caboose stove. Not saying it is one, normally when I see caboose stoves they tend to have a more pot belly look and tend to be bigger. Thanks for the correction might be a bit easier to research it knowing the right type of stove.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
