Can I vent my stove directly into the fireplace?
COALBROOKDALE Posted By COALBROOKDALE, Oct 12, 2006 at 2:21 PM
Thread Status:
  1. COALBROOKDALE
    COALBROOKDALE
    New Member 2.
    NULL
    Oct 11, 2006
    9
    0
    I recently purchased a wood stove and would like to set it directly into my fireplace. My question is can I just extend the stove pipe up to the fireplaces flue or do I need to extend the stove pipe through the flue up into the chimney. the flue is obviously not round so how can I fit it or adapt my current fireplace flue to allow the stove pipe to extend through and into the actual chimney. Is there some kind of adapter-cover plate?
    I have a new home with a masonry exterior chimney.
    Stove pipe from stove is 8"
    Stove is a Coalbrookdale Darby.
    http://stoves-direct.org.uk/stoves/multifuel/darby.html
    Thanks any feedback would be apriciated.
  2. Willhound
    Willhound
    Feeling the Heat 2.
    NULL
    Nov 20, 2005
    440
    0
    Loc:
    Northern Ontario, Canada
    Hello CoalBrookDale, and welcome
    Not sure where you are located, (from the link it looks like the UK?, or is the stove you are looking at installing from the UK?), but the first thing you should do is check to see what the local building code says and act accordingly.
    A quick answer would be that at the very least you will need a block off plate to keep smoke from pouting into your house in case of a downdraft.
    I personally would be more comfortable with a fully lined chimney. Do a search on "chimney liner" and a number of other threads will pop up.
  3. COALBROOKDALE
    COALBROOKDALE
    New Member 2.
    NULL
    Oct 11, 2006
    9
    0
    Hey thanks for the feed back, I'm just trying to figure out the best method.
    No I'm not in EuropeI'm located in New York State.
    The house and Chimney are new just 3 years old, and the chimney pipe is constructed out of the orange clay chimney material and brick enterior. Why would I need to line the entire chimney, does the stove over heat the clay or something? Gee I would hate to have to install and expensive liner, but I'm certainly not a expert on this topic. Is that the normal pratice to line a clay chimney?
  4. Todd
    Todd
    Minister of Fire 2.
    NULL
    Nov 19, 2005
    9,229
    349
    Loc:
    Lake Wissota
    Do you have a manual for this stove? It should tell the different venting options. Local codes may apply here to. You will definitely need a block off plate and at least a few feet of pipe to go to the first clay tile to keep the down drafts and the heat from going up the chimney. Also agree with Willhound about full liner for best draft and easier cleaning.
  5. COALBROOKDALE
    COALBROOKDALE
    New Member 2.
    NULL
    Oct 11, 2006
    9
    0
    No manual yet I'm working on getting one. They still build the stove in the UK so I can get spares and should be able to order the manual.
  6. webbie
    webbie
    Seasoned Moderator 2.
    NULL
    Staff Member
    Nov 17, 2005
    12,185
    1,087
    Loc:
    Western Mass.
    If you have the larger Coalbrookdale, then your chimney probably meets the sizing requirements without reline - in other words, if the stove is 8", and the chimney in great condition, reline may not be needed - BUT, at minimum use a "tube" of 5 foot flexible stainless steel to go up toward the first flue tile AND a tight fitting block off plate as per the article. That is how our shop installed dozens of Coalbrookdales in years past with few problems.
    If you are going to burn coal, make 100% certain that you install a CO detector! In fact, two would be the best bet. Coal gases can kill....another reason for having at least the tube and a very tight fitting block off plate.
    Note, if you chimney is not currently lined with terra-cotta tile, then you MUST reline.
  7. webbie
    webbie
    NULL
    Staff Member
    Nov 17, 2005
    12,185
    1,087
    Loc:
    Western Mass.
    Note the reasons for full lining - easy cleaning, better draft, less downdraft - in general a tighter job. Consider it this way - if you had to run a pipe from your cars exhaust though your living area, would you feel better about it being in a nice tight stainless pipe, or a relatively porous masonry tunnel?
    BUT, you may also run into problems if, for instance, you have an 8x12 flue - usually 6.5 x 10.5" inside - difficult to line with 8" (if your stove is 8")
  8. elkimmeg
    elkimmeg
    Guest 2.
    NULL
    Coal burning produces sulfuric acid which eats clay flue liners and concrete Coal requires cleaning in the spring afer the burning season to get the sulfur out of that chimney before the humid weather sets in, supplying the moisture the initiates the sulfuric acid formations. You may be able to use your existing setup. But a good 316Ti or 321 ti liner is added protection, that could prove to be money well spent. Don't know you size flue liners so, I can not advise how cross-sectional code applies. Is the chimney in an exterior wall? They do make round to oval band back to round ss liner to pass threw the damper. Again not the best for promoting good draft and stove opperations.
    Welcome aboard
  9. Marty
    Marty
    Feeling the Heat 2.
    NULL
    Jul 11, 2006
    284
    0
    Loc:
    Pittsburgh
    The best thing about going this way is you get to preserve your tiles if they are in ok condition now. The liner can be replaced relatively easily and cheeply by comparison with the tiles and you have a safer better drafting chimney.
    ...to do it with 316Ti you are looking at about $600 - $1,000 with insulation and not including any labor depending on the height of your chimney... 316 is also rated for coal and might be a little less ...or you could do it without insulation and save about $200...
  10. COALBROOKDALE
    COALBROOKDALE
    New Member 2.
    NULL
    Oct 11, 2006
    9
    0
    Does anyone have a link to a place I can get a "round to oval band back to round ss liner to pass threw the damper" ?
    What is the best sheet metal to use for the block off plate? I take it we should never use Galvanized?
    Also, I can buy coal in 40lb bags for $4 and a palet of 60 bags for $270 is that a little steep? i Guess it comes down to about 237 a ton
    Hey guys thanks again or all the help!
  11. COALBROOKDALE
    COALBROOKDALE
    New Member 2.
    NULL
    Oct 11, 2006
    9
    0
    Actually doing a little math it seems Wood may be my best bet.
    Since i got 2 cords of wood for $300 bucks
    From what I can gather it will take 1.4 cords of wood to heat the same btu's as coal which is about $210 in wood and 237 in coal.
    Anthracite Coal 1 Ton
    Wood (Air Dried) 1.4 Cords
Thread Status:
