I bought a used castile from a dealer and use it to heat a work area that I use during the day. The stove was a demo. Works fine except for one problem. If I turn down the thermostat (say in the evening) it will not restart when the temperature drops enough to call for heat. What it does is begin the start up [fan comes on, it drops initial shot of pellets, ignites, etc. ] However, then it does not continue to feed. If I press the reset button on the back, however, then it feeds pellets and runs well.
If on the other hand it is running, reaches the temperature on the thermostat and shuts down, the next time it restarts [due to the temperature dropping in the room some], it restarts fine.
It has something to do with me turning the thermostat setting lower.
The question is, could it be the thermostat? If yes, it is a simple fix. I just get a digital thermostat. However, I am thinking it is not that easy.
Any thoughts.
Bill McKay
Any thoughts.
Bill McKay
