I agree with your reasoning but uninsulated clay is going to cool quickly i dont think it matters much how far it stick out of the chimney honestlyyou want enough to get the top out of the turbulence from the cap and chimney, but not so much that the tip gets air cooled. You can get some nasty creosote buildup on the rim if it gets cooled by winter wind. 2-3 inches should be plenty and will allow a cap to be solidly attached. I would not go above 4" personally. I see a lot of liners going up 6 inches around here and they all have black around the top.
Ok what does the rest of the liner look like? Did you use fire clay to put together the new liner sections?Wood stove, I pulled 4 sections of liner 3 new and i need to buy another new section thats why the top liner is old. They cast the cap up there previously that is probably why I have the height difference now with the pre cast.
Ok then there is the answer. I always went with 2" so i guess that was a good thingNFPA -10. 7.2.13.3 says..."the lining shall extend for the entire height of the chimney to a level not less than 2 in above the crown ,splay or wash."
the top 4 block were replaced with brick mortar and the flues I used refractory mortar.
I only ask because it would be very uncommon to have the block deteriorate to the point of needing replaced while the liners are in good shape. Have you had the chimney properly inspected? Does it have proper clearance? what stove is it venting?The rest of the liner is good
That will work but if you are staying with the clay it would be a whole lot cheaper to just extend it with clay and be done with it.I'm just gonna have a piece of stainless bent to fit over the flue and screw it on to give me the min 2" clearance over the cap, then I can screw the rain cap to that extension
Ok but could you see if there were any cracks? Was the mortar still in all of the joints? Do you have the required clearance to combustibles?. If you are comfortable with it that is up to you but i can tell you from years of experience very little can be seen from above.I could see all the way down about 20'
ok then it is your choice.All nice and straight below the roof line, cleaned it and no visible cracks. I can't re-line this without breaking all the flue tiles so as of right now it is better than it was before.
