I have a question regarding the top plate installation on a masonary chimney.
I have a masonary chimney that has 2 flues in it. One is for the gas fired hot water heater and furnace that is in the basement and the other is for the fireplace which is in the first floor.
It appears that my chimney has 2 openings on the top. There must be some kind of clay tile liner in each one because there is a light tan rectangular protrusion coming out of each opening. These protrusions look to be around 4-6" high.
The top plates that I have seen are basically flat pieces of stainless around 13" x 13" and they have a round hole in the middle of them to accomodate the 3" flexible liner that needs to stick out 6" from the top of the chimney. Here is my question...
Because of the protrusions... there is no way to silicone the top plate to the surface of the top of the chimney. If I place it on the top of one of the flue openings it is suspended almost 6" from the top surface of the chimney. Are there custom top plates for this?
I look around my neighborhood at the other houses and they all seem to have the same light tan protusions coming from the tops of their chimney flues.
