Countryside Burn Problems
BobbyShea
2
Peyton, CO
I just purchased a new home that has a Countryside Pellet Stove. I cleaned everything out and fired it up. It burned great with a handful of pellets, but it doesn't seem to be feeding enough pellets to keep the fire burning. It has a very low flame and very few pellets in the burn pot.
Needless to say, it doesn't put out great heat and the glass get's covered in ash very quickly.
Any ideas?
Thanks
First thing is to take out the auger and that's very simple on the 3500. Empty the hopper, and take a piers and pull the auger out from the front. May be as simple as something on the auger not allowing flow of fuel. If that is good then maybe the motor gearbox is weak.
Welcome to the Forum! I am sure you will get this problem taken care of quickly! There is a lot of talent here. I would start by giving us the model of the stove and the year, if possible. The more detail you can give, the better we can understand the problem.
Have you ever owned a pellet stove before?
There will be a lot of questions asked which may not seem related to your problem but it all matters.
Thanks for the replies.. It turns out that the thermostat jumper on the control board was missing. This caused the timing for the auger to not function correctly. No matter what setting the heat was set to, the auger would only run every 20 seconds or so. After I replaced the jumper all the settings function as they should.
Thanks again
-Bobby
Reactions: briansol
Glad you found that! Great news.
Make sure the insides are cleaned too. You don't know when the previous owner gave it a full once-over.
Clean the pipes, motors/blowers real good and the flu passages.
