cutting selkirk double wall?
Jack Fate Posted By Jack Fate, Jul 17, 2013 at 9:08 PM
Thread Status:
  1. Jack Fate
    Jack Fate
    Feeling the Heat 2.
    NULL
    Jan 17, 2013
    431
    123
    Loc:
    Northwest Ohio
    decided to TRY too replace current set up of 2' double wall ,up to 90 & 1' to thimble stove pipe into masonry chimney on resolute stove to TRY to better draft. Changing to 2 -45's As I don't want to spend 6k + for what could a cobbled up mess / law suit .
    Any one cut this stuff ? The plan is cut off the chimney adapter by 1-1/2" using a dermal cut off for inside & metabo cut off the outside of the selkirk chimney adapter ?
    Is this reasonable ? oh & I had to put a damper in the line between the 2- 45's to get distance with the very limited selection of pipe options @ menards ( I got 5 pcs for about $100)
    Option one return stuff
    option 2 cut pipe if it don't work return the other 4 pcs.& eat $20 loss :rolleyes:
    I think i'm going in::-)
  2. Jags
    Jags
    Moderate Moderator 2.
    NULL
    Staff Member
    Aug 2, 2006
    17,509
    6,078
    Loc:
    Northern IL
    Sawsall with a long metal blade. Mark your cut with a piece of masking tape first. The tape edge is easier to follow than a sharpie mark.
    If you cut the pipe, will it still connect properly?
  3. STOVEGUY11
    STOVEGUY11
    Feeling the Heat 2.
    NULL
    Feb 12, 2008
    424
    3
    Loc:
    SOUTHERN CT
    Not quite following the set up here, but they typically make slip or adjustable lengths. That way no cutting would be needed. No you do not want to cut double wall pipe. It most likely states it right in the directions of the pipe not too cut.
  4. Jags
    Jags
    NULL
    Staff Member
    Aug 2, 2006
    17,509
    6,078
    Loc:
    Northern IL
    This is also my concern with cutting stove pipe. I don't see a way to properly connect end to end if you cut it.
  5. Jack Fate
    Jack Fate
    Feeling the Heat 2.
    NULL
    Jan 17, 2013
    431
    123
    Loc:
    Northwest Ohio
    Yes I understand the burred edge may not want to mate.
    Sawsall would be cutting both layers together no ?
    Inner pipe is shorter than outer .If I cut the inner out first with dremel cutting wheel ( its a large one for the dremel) then I could saws all the outer & deburr with dremel
    This pipe I'm cutting mates with the solid steel thimble .I don't think I'd try it on any other connection
  6. Jags
    Jags
    NULL
    Staff Member
    Aug 2, 2006
    17,509
    6,078
    Loc:
    Northern IL
    Why not use the proper slip/adjustable pipe?
  7. begreen
    begreen
    Mooderator 2.
    NULL
    Staff Member
    Nov 18, 2005
    64,931
    8,638
    Loc:
    South Puget Sound, WA
    Agreed. This pipe is not meant to be cut. When in doubt, call the mfg..
    1-800-992-VENT (8368)
  8. Jack Fate
    Jack Fate
    Feeling the Heat 2.
    NULL
    Jan 17, 2013
    431
    123
    Loc:
    Northwest Ohio
    Ok
    Ok option one
  9. Jack Fate
    Jack Fate
    Feeling the Heat 2.
    NULL
    Jan 17, 2013
    431
    123
    Loc:
    Northwest Ohio
    was enticed by cheap double wall at menards this week I learned 2 things ,you can't do things LOCAL when you live in the weeds and two ink doesn't refuse paper .thanks to all that answered the original post
    cheers
  10. Jack Fate
    Jack Fate
    Feeling the Heat 2.
    NULL
    Jan 17, 2013
    431
    123
    Loc:
    Northwest Ohio
    24" up from stove ,then 12' to thimble female connect to thimble that with a 90 between . sorry I live in the weeds
    this is based on stove & chimney that can't move . (above is what is currently connected stove pipe)
    hope this adds clarity
  11. Jack Fate
    Jack Fate
    Feeling the Heat 2.
    NULL
    Jan 17, 2013
    431
    123
    Loc:
    Northwest Ohio
    hmm not offered
  12. begreen
    begreen
    Mooderator 2.
    NULL
    Staff Member
    Nov 18, 2005
    64,931
    8,638
    Loc:
    If not offered then order online.
  13. Jack Fate
    Jack Fate
    Feeling the Heat 2.
    NULL
    Jan 17, 2013
    431
    123
    Loc:
    Northwest Ohio
    don't see adj. 4''-6"
    ONLY ADJ. is 12" -18" that's really 11.5-16" really
    & their band connection , sorry it 's not mechanically sound
  14. begreen
    begreen
    Mooderator 2.
    NULL
    Staff Member
    Nov 18, 2005
    64,931
    8,638
    Loc:
    Not clear, a picture would help. Up 24" and then what happens before the 12' of pipe?
  15. Jack Fate
    Jack Fate
    Feeling the Heat 2.
    NULL
    Jan 17, 2013
    431
    123
    Loc:
    Northwest Ohio
    12" to thimble not feet sorry not ft
  16. Jack Fate
    Jack Fate
    Feeling the Heat 2.
    NULL
    Jan 17, 2013
    431
    123
    Loc:
    Northwest Ohio
    fact of the matter is you can't do this at home ,you don't know the REAL MEASUREMENTS at least from this manufacturer
  17. begreen
    begreen
    Mooderator 2.
    NULL
    Staff Member
    Nov 18, 2005
    64,931
    8,638
    Loc:
    Got it, a very short run. Can you come off the stove with a 45 elbow, then slip connect to another 45 in the thimble? Something like this?
  18. Jack Fate
    Jack Fate
    Feeling the Heat 2.
    NULL
    Jan 17, 2013
    431
    123
    Loc:
    Northwest Ohio
    I could post pics of the boxes if that would help
    sorry sarcasm
  19. Jack Fate
    Jack Fate
    Feeling the Heat 2.
    NULL
    Jan 17, 2013
    431
    123
    Loc:
    Northwest Ohio
    ::P
    nope ,stove to close to wall , now your seeing it :eek:
    maybe if I could live with the band method 'NO I can't even then maybe not
    I fabricate plumbing in my job ,& now I can't cut :rolleyes:
    I want to cut this now just because :mad: then junk it
    sorry but I make junk work every day it's my job,then I come home & do it some more. difference is at home it has to agree with me ::P
    ok I answered question I ask in an other thread
    that's ok your the wall I bounce this off ,Thanks ;) for being there
    cheers
Thread Status:
