Hello
Replacing a door gasket is important to stop air leaks to obtain better fire performance. However the dirty, rusty area next to the door gasket contains that dirty ash and sometimes black creasote. Let's say it is a little SKANKY and putting in a new door gasket does not look so hot next to all this crud!
So what do most people do here?
Painting with high temp black paint works, but can be messy. So I tried some Dry Molly Spray. Since the Molly dries gray in color it seems to look great next to a nice new Graphite Impregnated Door Gasket!
See pics of the Harman P61a-2 fire door below. Click pics to Enlarge
Pic 1 - Frayed and dirty old white rope gasket
Pic 2 - Dirty area next to door gasket and dirty old door gasket.
Pic 3 - Dirty cam latch and dirty rusty screw heads and tabs that hold in window glass
Pic 4 - Wire wheel and drill drive used to remove all the old gasket and scrub off rust and dirt!
Pic 5 - Door is now clean but does not look as nice as it could.
Pic 6 - Glass was masked and a little Dry Moly Spray was used to protect from rust and look newer.
Pic 7 - Using Clear High Temperature Silicone holds the new gasket in and is easy to use.
Pic 8 - New Graphite impregnated door gasket installed starting in lower left hand corner.
Pic 9 - Masking tape removed and glass is cleaned. Molly dries fast and door should be left closed overnight for silicone to cure.
