Seasoned Oak it is 33 outside right now. I am sure that this wood can not be very wet if anything it is just above 20% max is 25 It has all the signs to be dry it clunks and alot of splits on the end. Again at this point I am frustrated with my decision and want to know if the non epa furnace will not be as hard to fire even if this wood is slightly wet.
begreen, I have no bends in my chimney pipe not sure where you got that at?
I am still leaning to the furnace now. Will it burn hotter and or better?
Also, if not the bigger blower will move the lower firebox temps better than this. I am just not going to work with this.
I am thinking that too it must be wood but my wood can not be that bad which makes me want to look at the furnace because if these epa stoves are that particular that is ridiculous.
Less than ten bucks will determine if improving draft will get you more heat. Seems reasonable.The double wall chimney pipe is more expensive then ten bucks. Also, I doubt that it is draft because from what I understand if I have a weak draft when I open the door all the way the smoke should come into the room and it does not.
