** Update: RESOLVED 10/29/11 **
Replaced circuit / control board (as well as the ignitor), on/off fan control works correctly along with all 5 variable speed controls - I am warm again , but it may be the burning hole in my pocket!
Okay, I've been pulling my hair out trying to figure this one out with no luck!
Pictured below is my 2002 Enviro Windsor which has kept me and my family warm and cozy for the last 7 or so seasons. As many on this board may know already, the convection fan speed setting is directly correlated with the heat level for this stove. Meaning basically, once the stove has completed it's ignition / startup sequence - manually adjusting the heat level up or down will directly increase or decrease the room blower. This has stopped functioning and I do not know why? I'm guessing it could be a faulty sensor or fan controller (which may be part of the control panel itself?) I just don't know.
Once the stove has started, the room blower use to kick right in (according to whatever heat level it was set on) and at that point you could control the fan speed by adjusting the heat level - this does not happen. The stove will operate fine for about 1/2hr - 45min. and then the convention blower will turn on full speed to cool the stove, this goes on for about 5 minutes and then the fan turns itself off again - this will go on indefinitely. The stove has a 160f sensor (as well as a 200f) in the air jacket, and what I think is happening is that the stove is getting to that temp, the sensor kicks in and turns on the fan - so I know that the fan does work.
The control board also has a manual on/off fan button as seen on page 6 of the Windsor owners manual (it is labeled #2) - this button no longer controls the fan.
I pretty much fully disassembled the entire stove and cleaned every nook and cranny - looks brand new now! I changed the gaskets, inspected wires, fuses, control board for shorts, etc - everything seems fine. I thought at one point the stove may have been somehow stuck in a high/low thermostat mode (never used this function) - so I tried every jumper configuration which didn't fix the situation (returned jumper to original setting). Not sure if it's relevant, but the ignitor hasn't been replaced in 6 or 7 years and works only half the time (I just don't think it's getting hot enough?).
