Double wall pipe..18 in? or more?
Thats what I am running into...I won't have a choice but to go thru the overlapped section...be alright doing that I guess?I would just follow the directions. I think it's supposed to be 18". I fudged mine a tad lower so that didn't have to drill through the overlapped section of the double wall slip joint.
24 puts her about eye level...Put it so that it's easy to read, no closer than 18" or the thermometer will read a bit high. Ours is at 22".
From Condar:
Position so the thermometer can be read easily at a glance...
When properly installed, the FlueGard accurately reads flue-gas temperatures, with an error margin less than 5%. If placed closer than 18 inches from the top of your stove or furnace, the thermometer will read slightly higher.
when running the stove on low you will see real low temp in the 200df but it is ok.
The cat is running midrange active and the flue probe is running 500...cruising right along...I do not believe that it is okay to run the stove with 200 degree flue temps. Think about what you're doing, condensing all of that water vapor into liquid within the flue. Nasty mess. There is a reason that the condar flue probe meter says anything under 400 is too cool. Oddly, the newest version of fluegard meter seems to think that 350 is the new low limit.
Its running on al load of well seasoned red oak...I couldn't play around with getting it up and running as the wife will be home soon...lol pics in a few.It's already running? You're going to need to post the install pics. We all love the pics.
closed...it is holding steady at 500 now.The cat is glowing a steady orange and it appears to be cruising right along...is that to high?600º flue temp? Was this with the bypass open or closed?
Don't know, that's why I asked. May depend on the thermostat setting and a new stove will have a strongly active cat.closed...it is holding steady at 500 now.The cat is glowing a steady orange and it appears to be cruising right along...is that to high?
I had the t-stat set at the 3 o'clock position initially(when pic was taken)and it is now set at 2;30 and is running at 500 and holding steady and this is a brand new stove being fired for the first time todayDon't know, that's why I asked. May depend on the thermostat setting and a new stove will have a strongly active cat.
Congrats on the new stove.
Curious about the 600º flue temp. Was this with the bypass open or closed?
I'm surprised the flue temps are so high with a cat stove. On my tube stove i usually peak at about 600 flue temp then when I make my final air adjustment it sit around 450-500 until the wood is all coals.
Good to know. These readings are similar to my flue temps of about 100º below stove top temp.In this cold weather I've been running the stat at 50%, cat engaged, and the flue temps sit at 600 during the first half of the fuel load. Maybe 8 hours and slowly drops to 500. Only low burn rates get me to 400. Ultra low burn rates get me down to 200-250 with an active cat but that will lead to condensation in the flue so I try not to drop below 400.
