foam board inside walls????
sleepie Posted By sleepie, Jul 14, 2008 at 5:03 PM
Thread Status:
  1. sleepie
    sleepie
    New Member 2.
    NULL
    Dec 2, 2007
    65
    0
    Loc:
    elmira, new york
    i have an attached garage --turning into a room--it already has 3.5 fiberglass in the walls--they are not sheetrocked yet---should i cover them with foam board first ---then sheet rock over ---anyone have any thoughts??? cost effectiveness --will it make the room warmer? and cooler in summer? thanks for any help..
  2. Willman
    Willman
    Minister of Fire 2.
    NULL
    Jan 15, 2008
    669
    6
    Loc:
    Sabattus Maine
    Foam board over studs is an excellent thermal break. Studs transfer heat out. Just need to extend your electrical boxes. I'd use the good foam for the best R for the inch.
    Will
  3. Highbeam
    Highbeam
    Minister of Fire 2.
    NULL
    Dec 28, 2006
    12,361
    2,096
    Loc:
    Cascade Foothills, WA
    Is the fiberglass faced? That's your vapor barrier and by adding more insulation over it you will have youe vapor barrier in the middle of the insulation vs. the warm side where it is supposed to be. I'm pretty sure that the typical location for a foam layer is outside the studs before siding. If on the inside you'll need to add the sheetrock and how will you locate the studs? You'll need really long screws.
  4. sleepie
    sleepie
    New Member 2.
    NULL
    Dec 2, 2007
    65
    0
    Loc:
    elmira, new york
    was thinking of using the fan-fold 1/4" insulation they use under siding---i have 3.5 insulation in the walls now with paper facing the living space---i thought the foil-styro stuff would keep heat in in winter and hot out in summer---and a styrofoam cup is not much more than 1/4 inch thick---the stuff is cheap enough ---and not too much a hassel with the outlets---as i am using 1/2 sheetrock and not 3/4-------any more thoughts here,,,i schedualed to begin in october with this---thanks pat
  5. fossil
    fossil
    Accidental Moderator 2.
    NULL
    Staff Member
    Sep 30, 2007
    10,550
    2,421
    Loc:
    Bend, OR
    Why not just pull out the 3.5 and install R-16 or R-19, sheetrock & be done with it? It'll be more effective than trying to build your own sandwich. Highbeam's point about the location of the vapor barrier in the wall is an important one, as well. Rick
  6. pete324rocket
    pete324rocket
    Feeling the Heat 2.
    NULL
    Nov 11, 2007
    472
    6
    Loc:
    albert county, new brunswick
    The reply that mentioned the thermal break was good advice. It will interrupt the flow of heat thru to the outdoors via the wooden studs which have little r value. The white "bubble board" is probably the best deal for the money for this.
Thread Status:
