Does anyone run there generator from there basement? Or do you have it outside and running cables back into the house? I know they say not to because of CO but was just wondering how people rig it.
Please don’t ever run a generator directly from cables into the house. Have it installed properly into your breaker box so that it won’t back-feed to the lines outside your home. My husband is a lineman for one of the utility companies here in Massachusetts. His life depends on every generator being installed correctly.
During outages of the scale that New England is experiencing at this moment, this is among the greatest risks he faces. He’s careful; he knows that people do it. But do please take the extra precaution and have the generator properly installed.
kast said:haha yeah wasnt really planning on it, do you have one? how is your setup?
I bought a Generac 12kw whole house unit back in ‘03, so it’s set-up outside permanently with auto transfer switch.
kast said:So let say your power goes out, you pull this thing from say your shed where then do you place it to run (has to be out of the elements right?) then how do you run the cable into the house with out running it threw say an open window.
macman said:I bought a Generac 12kw whole house unit back in '03, so it's set-up outside permanently with auto transfer switch.
This is what i have:
tinkabranc said:If you install a manual switch, get the inlet box installed to the side of the house.
Then you just need to run a cord from a portable generator to the outlet.
No cords thru the house.
OR if you make the big bucks like macman, you can get an auto switch with standby installed. ;-)
kast said:Can you explain back feeding? Sorry clueless about Generators
lass442 said:Please don't ever run a generator directly from cables into the house................
lass442 said:All taunting aside... I admire macman for installing his Generac safely.
