I have read here that some of you have yours in another room or 15-20ft from the stove.......mine only came with maybe a 3ft legth....is there longer ones out there to purchase?...or are they self made?
self-made. Just get a hunk of thermostat wire from the local hardware store, and some of those flat crimp-on connectors to make your own extension.
Many people just leave the factory-supplied length behind the stove, and say that it works fine there...the theory being that all that "return" room air being drawn into the distribution blower should give an accurate assessment of the room temperature. I didn't have such luck. I don't know if its because my stove is in a corner, or what, but the room won't get above 70 if the probe is anywhere near the stove. I suspect its because of the corner, and nearby furniture...the radiant heat bouncing off all that stuff is enough to fool the probe. (tested this w/ a thermometer...everywhere I tried to stick the probe, I put a digital thermometer in the same spot, and sure enough...it read the same as the stove's setting...while the rest of the room was much cooler). After extending the probe, and running it 10' up an adjacent wall, sticking up behind the couch, the stove keeps the whole room at the set temperature.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
