hoverfly
Guess I should go blow down my pellet stove...
Just do not inhale, unless the pellets are made from hemp? Or does your stove have a name?
As the box says "pellet stove cleaner". Funny thing I had my vent pipe cleaned just yesterday and there a a small amount of dry black creosote that came out. Maybe that chit really worked?Well, you can try this:
https://www.hearth.com/talk/threads/took-one-for-the-team-csl-pellet-stove-cleaner.101029/
However, from the Q&A on the CSL website: "Q) Can CSL be used in a pellet stove fireplace insert?
A) NO!! you cannot use the CSL in a pellet stove. Pellet stoves are intended to produce very few smokes. However, it requires regular visual inspections."
I assume that was written before they came out with the CSL pellets.
Can we call it fire?exothermic chemical reaction of rapid oxidation
I do know that if you provide a negative pressure and pass the byproducts of combustion thru water its not as harsh on your throat as if you don't
can we call it a Hooka
I have to believe that if you could increase efficency by preheating the air for combustion, the people that make and test these things would have figured that out. I think that the systems that have the outside air inside the exhaust do it for convience more than anything else. Just my gut feeling.
so what your saying is it takes no energy to heat the combustion air? I'm sure your not saying that. Any energy that is not used to raise the temp of the combustion air will go twards raising the efficency...it has to. No "gut feeling" just logic.
Yes, but that is wasted heat going out the exhaust, so why not use it to warm combustion air? Like burning trash for energy.
sorry to intrude. Is that a fact?if your combustion air is say zero degrees and it goes into the combustion chamber ...it is going to rob 100 degrees of the combustion energy.... that combustion air that goes in at 100 degrees wont.
I doubt that is fact....
The flame that is say.... Around 1,500° isnt going to care if the incoming air is 70° or 20°… 95% of all air passes through the pot (give or take due to air wash and other burn pot bypasses) so that 95% of the air at a 50° difference isnt likely to disrupt a flame that hot??
Maybe I am wrong. But OAKs provide cooler air. But my stove GAINED Efficiency when I installed it. Cooler air is more dense and contains more O2. Why do Super Charged engines and Turbo Charged engines try and get as cool as air as possible??
Again. A flame that hot, will not care of such a minute difference when talking Thousands of Degrees.
Maybe I am wrong. But until a fact comes up. The 50° air differential won't make a 1,100°-1,600° fire even sputter.
How hot is the flame? How hot is your air?
Engines or Air pumps (pellet stove, yes an air pump, very similar to a Super charger)
A pellet stove is a Giant air pump with a feed system. That's it. Nothing more. Nothing less.
Not gonna pick your post apart. But your argument is basically that a regular OAK (cold air) will decrease my stoves efficiency?? Ludicrous.
How hot is the flame? How hot is your air? Engines or Air pumps (pellet stove, yes an air pump, very similar to a Super charger) A pellet stove is a Giant air pump with a feed system. That's it. Nothing more. Nothing less. Not gonna pick your post apart. But your argument is basically that a regular OAK (cold air) will decrease my stoves efficiency?? Ludicrous.
