High Pitched squeal. Englander PDV
kdp7462
63
Hi All
Earlier this week I pulled both blowers from the stove and really went through a good cleaning getting ready for the winter. Stove has run awesome the last 3 days. Anyway, I have had it running since about 4 this afternoon, but in the last hour or so, it has a high pitched squeal coming out of the exhaust blower area. It only seems to squeel when it is fired up. I have turned it off and let flames go out, and it stops. If I turn it back on, once the flames get going I get the squeal again. Any idea why this would be happening?
kdp7462 said:
Hi All
heat could be affecting the bearing on the inside of the blower motor. how old is the stove?
Thanks Mike!
I figured that maybe the root cause, so I let the stove go cool(room blower off). I then restarted it, and it has been fine since. The stove is going into its 4th season. Should I be worried that I will need to be replacing the blower this year? I just cleaned it and the inside looks good.
its a possibility, ive seen em squeal for a while and stop and run for years , and ive seen em squeal and stop and lock up soon after. so theres no "set in stone" answer for this. i'd consider maybe ordering one just in case , if the blower keps on trucking put the new one on the shelf , eventually any motor will wear out and that thing has a pretty tough life to lead. the new one wont exactly rot sitting on the shelf either.
