How high (temperature) can you crank your pellet stove?
Don2222
9,117
Salem NH
Hello
Just doing some testing on the P61-2 with the heat gun approx 1 foot away and the Feed Rate on 2 and the room fan on low.
I got 516.2 Deg F ! ! ! Got 477.3 Deg F on the sides!
What do you get?
I wont measure with a Infrared gun do to all stoves being made different.
What really matters is the actual air temps. A T/C placed 1" away from the end of a heat exchange tube still isnt equal playing griunds, but its much closer than the box temps with a IR Gun.
IMO... Use a k-Type t/c 1" and we can compare. Some stives have better shielding and wont post high steel temo. Air temp is what heats the room (convection).
Hello
399 Deg F is getting up there! What brand thermometer did you use Scott?
Here is the Cole Palmer with the high temp probe 1" away - 521 Deg F ! ! !
I cranked the stove higher this time! ! !
This would be a good shed heater? LOL
Click pic to Enlarge:
Not familiar with that term. What is a k-type T/C?
K type thermal coupler can be a simple wire that just clips into a thermometer. It measures the heat using the resistance of the wire at the end.
you know what I'd be curious about...how about exhaust temps? Which stoves emit the highest amounts of heat in the exhaust? As we all know, this is lost heat....
In one of my conversations with Mike Holton he stated on the Englander stoves, the exhaust can get as high as 550 Degrees depending upon all the settings so vacuum hose for the air switch must be rated at 600 Degrees which is what I use.
If we remember our physical science, temperature and heart are two different things. Related, but not the same. Temperature is the measurement of the average speed of the particles being measured while heat is the energy of the sum of the speed and mass of the particles. In other words the amount of heat produced in a chemical reaction is not really related directly to the amount of heat produced. A pail of cold water has more heat energy in it that a red hot iron poker. (just a silly example, but true)
youch, man! I can barely get my shoes on the right foot each morning.........anyhow, I digress.....regardless of terminology, simple logic would dictate that the more heat/temperature/whatever which leaves the exhaust of the stove is lost to the atmosphere, and thereby, its lost heat, pure and simple......Smokeater must be some kinda politician or something....;)
Maybe we need a Magic Heat for Pellet Stoves?
http://www.northerntool.com/shop/tools/product_200331508_200331508?cm_mmc=Google-pla-_-Heaters, Stoves + Fireplaces-_-Heater, Stove + Fireplace Accessories-_-17278&ci_src=17588969&ci_sku=17278&gclid=CL7z9NXDnbgCFcSf4AodLWMAEA
Scroll down to see the pics of a guy who installed one on his boiler to heat his basement! ! !
cant imagine the exhaust issues, let alone trying to get folks the clean the thing!
Many Pros and Cons about this unit over the years but they still make them and sell them! LOL
we've sold em too....I recall a conversation on the heat gained versus the electricity to run the thing...yea, verdict is out there, but given a positive pressure exhausting appliance, the restriction to flow might cause issues....then, maybe not......
Temp is only one part of heat loss up the stack or out of the convection vent. Heat out is mass flow rate multiplied by temperature multiplied by time. Or you do mass flow rate multiplied by temperature to get heat per time. Low flow high temp can be less heat output than high flow and low temp.
When I worked for a manufacture of pellet stoves we cranked one stove up with pinnacle pellets and the heat exchangers glowed red at 6 pounds per hour. These were 7 gauge 301 stainless heat exchangers. We could never find another pellet that would make the heat exchangers red. It was well over 550 at the exchanger.
Wow, that must have been cool!
How about Hamer Hot ones? Did you try those?
Probably not. Politicians aren't that knowledgeable. At first I was going to say not that intelligent, but seeing the cushy jobs they have, they must have some kind of intelligence.
Reactions: Lousyweather
