http://www.americanenergysystems.com/model2insert.cfm
i think i have finally found out what i will be using, a zero clearance approved fireplace insert.
now i am looking for one that can provide the most heat as my home is 3000SQ feet, and i would like to have this unit supplement my house furnace over the winters.
i like the looks of the 02 insert, but first hand reviews of it would be most beneficial. can it really heat up to 2500 sq ft? probably more realistically around 2000 sq ft?
is there any other make/model i should consider that can heat that sort of square footage or better?
i am sold on wood, and inserts that are for zero clearance as that is what i have to work with at the moment. i do not wish to incur the added cost of redoing my fireplace to accommodate a higher efficiency unit, so a ZC unit will have to do for now.
any personal experiences or information would be much appreciated.
thank you.
thank you.
