Oldspark, I also have a red Summit Classic, with 4 foot of single wall inside, a through the wall kit, and then 12 foot of triple wall SS. I do not have a blower. My results seem a bit different than yours though. My Rutland magnetic thermometer is usually about 6 inches above the stovetop on the single wall pipe. This stove heats the place nicely as long as the flue temp is 400 or above. I took out the trivet and placed the thermometer on the stovetop, and it consistently reads over 100 degrees higher than the flue temps. Right now with a flue temp of 300 on a stove with only coals in it the stovetop is 450, and the primary air is fully closed and has been for an hour.
For max heat I pick out the densest wood from the pile, and then get it hot... ie. the flue temp hits 400-500 before I start to turn it down. Somewhere between 500-650 I will finish turning it down, usually ending up with the primary air open approximately one inch left of fully closed. If the flue temp drops below 450 shortly thereafter I turn it back up, and make sure the flue temp is at least 600 for a few minutes. Yes, I have hit well over 600 flue temp on this stove, and the two feet of pipe closest to the stove is whitened to prove it. However, if I move my thermometer closer to where it goes through the wall, the flue temps have dropped considerably. My SS does not see the high temps I measure inside because the single wall radiates quite a bit of it.
Like you though, I have been surprised at the lack of felt heat compared to my old stove, a US Stove Wonderwood with a sheet metal firebox that ate tons of wood and radiated unbelievable amounts of heat, making the stove room uninhabitable. The Summit is much more comfortable in the stove room, and keeps the rest of the place in the low to mid 70s, unlike the old stove which was a struggle to keep the main living area under 80. My problem isn't the stove though, it is the lack of proper insulation in my 1966 mobile that I am trying to heat. My wood to start the winter wasn't dry enough, and my draft just wasn't quite enough. I added three feet, and the stove drafted dramatically different. I brought two weeks worth of wood inside much like Battenkiller did, and let it dry at least a week before I burnt it. At the beginning of winter I was comfortable with outdoor temps of 20 F and above... today I can keep it 70 or above overnight with outdoor temps around 0 F.
If you are curious, I weighed a few of the pieces I brought in the other day. One was silver maple, the other was mulberry. Both were c/s/s before April 15, 2010 uncovered in the sun. The silver maple lost 4.2 oz and the mulberry lost 3.4 oz., weighed with a postal scale.
