more pellets to feed
chrisasst
1,289
cortland ny
I know no one else has the stove I have, but how would one get more pellets to feed into the burn pot. If I throw in pellets into the burn pot manually, the temp output goes up, but the pellets burn up immediately. So I am wondering if my stove is not feeding enough pellets. However if I close the damper, the pot just fills up and doesn't burn correctly.
I was hoping there was a feed trim adjustment for each fuel setting. Unfortunately there is only a feed trim for heat range 1 on that control and it doesn't effect the other heat ranges.
Not much you can do with it, Besides hitting the auger button to feed some extra fuel in here and there. Sorry! Only other thing is to look for very dense pellets that are small in size and short in length. These will give you the max fuel charge possible. Something like Barefoots, Hamer Hot Ones and Okies maybe depends on your stove and the batch you get. Another thing if your bored is to try breaking up a bag of the Cubex into pieces no bigger than 1/2 inch long to see if my theory works for this stove. You should see a more consistent fire by doing that.
Keep us posted
I cut all mine to 3/4 inch long as I stack them next to the stove ;-)
