Hey guys. Well I'm on about my 4th burn with my napoleon. I have a few quick questions. When I start a fire when I get home from work, my thermometer says the box is a round 200. I'll throw a couple logs on hot coals, and the thing will take off. I'll shut the door, and the primaries will be going good. Maybe 10-15 minutes into it. The fan will then kick on, the thermometer will read 250, and the baffles up top will have a slight glow to them. Too hot? It seems to me that the inside of the box gets hot very fast, but i'm only seeing temps around 300. I've attached a video of it. The first video, the fire has only been burning for at 15 minutes, and the damper has been fully closed for about 5 minutes. The second video is about 40 minutes into the fire, damper has been fully closed the whole time, and the baffles are still glowing.
When I got home yesterday, I loaded her up good, and choked her all the way down. The wood had been seasoned for about 3 years, wicked dry, but there small splits I got for free. I was about to put 11 splits in. Thats how small they are. But I was able to get the stove top up to 550ish for around a hr, but the baffles were glowing the whole time, and the stove top temp was decreasing? mind you the draft was fully closed. I let those logs burn down to hot ash, took about 4 hrs. At this point, the stove top read 250. I loaded her up for the night, and right when I put the logs in, they started, and the secondaries kicked in, and the baffles started to glow again. It seems to me like the stove is either wicked hot in the inside, or cold. no in between.
http://www.youtube.com/watch?v=L7zX1J9__iw
http://www.youtube.com/watch?v=JYleRtzsFXw
