    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. ARGlock Feeling the Heat
    Arkansas
    The board we have only shows: On/Off, Combusion Blower Trim, Feed Rate Trim, Switch: Manual, Low/High, Auto/Off , Then the 1-5 Heat level indicator and the Heat Level Up and Down Arrows. It's listed in the Enviro Pellet Stove Service Manual on page 15 and has the number on the description on the page as C-11825. It would be Daughter Generation II Control Board.
    Looks like this saga will run into tomorrow (Monday).
    Thanks,
    AR
    #26
    Helpful Sponsor Ads!
  2. Hellfire Member
    Sunbury , PA 17801
    This will reveal any auger issue:
    If Possible this will test the auger independently:
    Strip the ends and attach some connectors the opposite of the augers load(feed) wire ,typically male is put on the plug but for safety reasons i put 2 female types to protect yourself from the male type.(as its unsafe if accidentally touched!);ex
    I then make a pair off converted jumpers to convert it for desired application and go from there(depends on the type of connection i need)
    Jumpers are good for bypassing things for testing.
    Just remember before you plug it in LIVE make sure you wont short out or shock yourself.:ZZZ
    ie: any cord such as an old computer or extension cord will work.
    Spade connectors are avail. from hardware store, walmart ,ect just get same size.
    See how much you get flowing out of the burnpot.
    [IMG]
  3. SmokeyTheBear Minister of Fire
    Standish, ME
    AR,
    With the stove off and unplugged check the cable between the daughter card and the main board and make certain the connections at both ends are solid. If this connection is iffy the main board might not be seeing the t-stat mode switch on the daughter board..
    Also verify that the main board and the daughter board you have are correct for each other.
    Then verify that the t-stat connections are good to the main board.
    I've found at least three different sets of information on the Milan.
  4. ARGlock Feeling the Heat
    Arkansas
    Thanks for the info!!! I'll run by the site tomorrow and see what we can come up with. It sounds like they have made several revisions on the Milan unit over a period of time. This can create many questions as we are seeing.
    AR
  5. SmokeyTheBear Minister of Fire
    Standish, ME
    How is it going?
  6. ARGlock Feeling the Heat
    Arkansas
    We got the Milan going perfectly! The Enviro Tech explained the problem. We were changing up the air mix during the 15 minute startup phase and this was causing the malfunction. After we set the air at .13 on High fire the fire was perfect. Before we could not get a decent flame on ANY setting. It must have confused the computer enough that it would not work anywhere.
    Anybody know why the computer or whatever component would act like this by just changing the air setting on the front during the startup phase?
    Thanks,
    AR
  7. SmokeyTheBear Minister of Fire
    Standish, ME
    Most controllers lock out the user until the stove exits startup.
  8. Hellfire Member
    Sunbury , PA 17801
    :)Excellent:)
