    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
Thread Status:
  1. Mbgame New Member
    Enfield Ct
    I have a Harman Accentra pellet stove on the way to be installed in a few months and I was wondering if it was possible to make a hearth pad by using concrete. The pad would be going over the top of the existing hardwood floors and be 4 inches thick. I was thinking about making it following concrete counter top instructions and installing molding in the form box to give it a little bit of detail along with black dye to get it to resemble cast iron as much as possible. After reading a few articles on R-values and other construction ideas I wasn't sure if just plain concrete would cut it. Any feedback on my idea would be great. Thanks
    #1
    Helpful Sponsor Ads!
  2. begreen Super Moderator
    South Puget Sound, WA
    As long as it meets the hearth size requirements this should be no problem. Like many pellet stoves, the Accentra has very minimal hearth requirements.
  3. Drivr Member
    Seacoast, NH
    I'm guessing your never going to move this pad. a concrete pad say 4 ft square and 4 inched thick is going to weigh in the neighborhood of 710Lbs. But I bet it would look nice.
    Double checked my math, 4x4x.3=4.8(cubic ft), 4.8x148=710.4. from what I remember 1 cubic foot of concrete with Portland cement weighs around 148 pounds. Make that pad 3 inched thick instead and use fibered concrete for support and it will weigh only 592 pounds instead of 710 pounds.
  4. hoverfly Feeling the Heat
    Southern NH
    Here is a lighter, version 3/4" ply wood, at least 3/8" thick tiles and between the tiles and ply 1/2 cement board, this one is optional. Or 3/4" ply build around a raised border and fill it with cement.
  5. hoverfly Feeling the Heat
    Southern NH
    Here is a lighter, version 3/4" ply wood, at least 3/8" thick tiles, between the tiles and ply 1/2 cement board, this one is optional. Or 3/4" ply build around a raised border and fill it with cement.
  6. Mbgame New Member
    Enfield Ct
    [IMG]
    This is the shape and rough size of the hearth idea. After reading the post about the weight I plan on reducing it down to 3 inches thick. With those measurements using fiber reinforced concrete it should weigh 340lbs if I did the math right. It should span 4 floor joists with the back of the stove next to a load bearing wall. With the stove the total weight should be 710lbs. I'm pretty sure the floor can handle it, the other end of the room has an aquarium that totals out at around 1400lbs and covers 3 joists with a load bearing wall in back of it. I hope it supports it anyway! Once again though any hints, tips or ideas are more than welcome.
  7. johnnywarm New Member
    Connecticut
    Support the floor before you go forward.
  8. slls Minister of Fire
    central maine
    All you need is a non combustible surface. Out of the Harmon manual, 20 gauge sheet steel will be sufficient. Just an idea of what is required, you can go up from there. Here is mine, ceramic tile on ply wood.
    [IMG]
  9. Drivr Member
    Seacoast, NH
    Ive seen people use 6" thick solid concrete blocks for a pad under a wood stove and had no problems with the floor. your going to be spanning 4 floor joists I don't think you would have any problems with this. but then again I'm not a carpenter or an engineer.
Thread Status:
