jtakeman
I have never hear of any safetys that are tagged out by the stove makers. Don't mess with that.
The napoleon shoukld have a digital controller(DHC3000 IIRC) and will flash an error code. One of the heat level indicatorsill flash once the stove has gone through the cycle. Start the stove and let it go until it shuts down and tell us what heat level is flashing. In the anual it will have a list of codes and what the issue related to the code is.
I'm betting its the POF is stuck and could only require a tap(light tap with the handle of a screw driver). And it should run. If not contact the dealer and request a new POF switch. I would try jumping it, Some of the newer controller monitor if the POF is stuck closed and it will only cause another error. I test with a toggle switch connected to the wires that go to the POF. Run the stove with the switch off and around 5 minutes in turn the switch on. Mimics the POF.
