Newbie here - PE Summit ordered right now
Hi all,
thank you for such a nice forum which helped me a lot in selection my new chimney.
I decided for PE Summit, I should receive a "B" generation - looking forward to it. I'm not living in US nor in Canada - I'm from middle Europe (CZ if you look to the map, right next to Germany).
I'm quite sure I will be one of the very first "B" generation (hopefully) happy owners here in Europe :)
And small question: what is the maximum chimney draw allowed for this stove? Actually I have 6 meters (=20 foots) SS chimney with diameter 200mm (approx 8 inch), well isolated. It will create draw about 25 to 30 pascals (depending on temperature).
Any experiences with similar configuration? Should I install a draft regulator? http://www.pexsupply.com/Field-Controls-6-RC-6-Draft-Regulator-for-Wood-Oil-or-Coal
Regards
Jan.
The stove calls for 6" chimney, minimum height is 15'. So your good on the height. The diameter may or may not be an issue.
Try it out and if it gets a good draft with the 8", your fine. If the draft is sluggish, you may have to try extending the stack or swapping for 6".
Congrats on your decision of the Summit, and enjoy. It is a great heater.
I doubt you will need a damper. If you do, get an inline pipe damper.
