Noisy pellet stove
turtyle Posted By turtyle, Apr 30, 2013 at 9:16 PM
  1. turtyle
    turtyle
    New Member 2.
    NULL
    Apr 30, 2013
    3
    0
    Loc:
    Yelm, Wa
    Being new to pellet stoves, I'm not sure why mine occasionally makes a deep "thrumming" noise...could it be the sawdust from the pellets? I use Olympus Ultrapremium (Doug fir). thanx everybody!
  2. mralias
    mralias
    Minister of Fire 2.
    NULL
    Apr 29, 2008
    989
    215
    Loc:
    MA
    Welcome. Post your stove type in you signature. You will get more responses that way. When does the noise start and stop? (What part of the cycle?)
  3. DexterDay
    DexterDay
    Guest 2.
    NULL
    Is the noise coming from the stove at start up? Shut down? Normal operation?
    From a motor? From the auger? Is it consistent? Is it the fire rumbling?
    Lots more info needed. It can be a number of things.
    Welcome to the Forums. :)
  4. imacman
    imacman
    Guest 2.
    NULL
    Doubt "saw dust" has anything to do with it, unless your stove hopper is full of fines. In any event, we can't do much to help unless we know what make & model stove you have, as mralias states above.
  5. BrotherBart
    BrotherBart
    NULL
    Staff Member
    Nov 18, 2005
    32,824
    9,888
    Loc:
    Northern Virginia
    My 25-PDVC does the same thing. Don't know why or what causes it.
  6. imacman
    imacman
    Guest 2.
    NULL
    There is a thread that Mike H. responded to sometime back. He said if you cover about 1/2 of the air inlet with duct tape, it stops a "drumming" sound in the PDVC. Small adjustments of adding or removing thin strips can "fine tune" the fix. Might be worth a shot.
    stoveguy2esw likes this.
  7. turtyle
    turtyle
    New Member 2.
    NULL
    Apr 30, 2013
    3
    0
    Loc:
    Yelm, Wa
    Hi everyone...thanx for your input on the noise problem. We have a Heatilator ECO-ADV-PS50. The noise occurs only occasionally, and only when the augur is feeding pellets. We have cleaned the stove on a weekly basis since fall of 2012, and also VERY thouroughly twice (I took it apart) in that time. I have noticed that the noise only happens if there is sawdust (fines?) in the hopper. The stove was purchased new in July 2012. Thanx again!
  8. mralias
    mralias
    Minister of Fire 2.
    NULL
    Apr 29, 2008
    989
    215
    Loc:
    MA
    Feed Bearing on its way out perhaps?
    SRV7000-598
  9. turtyle
    turtyle
    New Member 2.
    NULL
    Apr 30, 2013
    3
    0
    Loc:
    Yelm, Wa
    I suppose it could be, but we bought it new just last July, and had no problems of any kind until we got a load of sawdust (is sawdust the same as "fines"?) in the hopper. Other than this minor annoyance, the stove has been a jewel...Thanx to all!
  10. mralias
    mralias
    Minister of Fire 2.
    NULL
    Apr 29, 2008
    989
    215
    Loc:
    MA
    Yep sawdust and fines are one in the same.
  11. stoveguy2esw
    stoveguy2esw
    Minister of Fire 2.
    NULL
    Nov 14, 2006
    6,185
    1,101
    Loc:
    madison hgts. va
    i do ;)
  12. BrotherBart
    BrotherBart
    NULL
    Staff Member
    Nov 18, 2005
    32,824
    9,888
    Loc:
    Northern Virginia
    ;hm
  13. stoveguy2esw
    stoveguy2esw
    Minister of Fire 2.
    NULL
    Nov 14, 2006
    6,185
    1,101
    Loc:
    madison hgts. va
    does the fire "change" when this noise is occurring? does it sound like a truck way off in the distance?
    if the fire "shakes' as the noise comes and smooths out as it subsides its an air pressure thing, kinda like cavitation in a boat propeller. restricting the intake a bit will usually help if this is the condition im thinking of. you would want to do it while the stove was running AND doing the rumble thing so you can adjust your restriction based on results as its doing it.
    FWIW it does not harm the stove at all if this is the issue.
    oops , just re-read the post. does your hopper lid have a seal? im not familiar with that model, but with some stoves (usually top feeders) which do not have a sealed hopper the airflow through there is kinda factored in if you have a bunch of fines in the auger sleeve it could be restricting this air as the auger is turning and causing an air difference as well.
    its really hard to pinpoint this issue you speak of without a really detailed description or possibly a recording of the noise to "go on"
