I was considering purchasing a Quadra Fire Stove. Does anyone have any experience with a Isle Royal or Cumberland Gap? What do you like - dislike? What kind of burn times can you get?
Thanks!
Thanks!
shilohfarmboy said:...Fossil- Can I install my own insulated liner? Where can they be pruchased? Are they stainless steel or something else? The DW is 11 years old. It is connected to the chimney with a 6" SW pipe and 1 elbow, about a 3' vertical and a 3' horizontal run. I've cleaned the catalyst once in the last 3 year, but I did not seem to make any difference. I haven't done any other maintenance on the DW in the last 3 years other than cleaning, door seals all look good. The chimney is kept fairly clean but not perfect. I have the owner's manual it it claims a max burn time of 9 hours. Will installing a insulated chimney liner transform my DW into a "new" stove? Am I just wasting my time and money if I purchase a new Quad? (I plan on installing a liner with the Quad)
fossil said:shilohfarmboy said:...Fossil- Can I install my own insulated liner? Where can they be pruchased? Are they stainless steel or something else? The DW is 11 years old. It is connected to the chimney with a 6" SW pipe and 1 elbow, about a 3' vertical and a 3' horizontal run. I've cleaned the catalyst once in the last 3 year, but I did not seem to make any difference. I haven't done any other maintenance on the DW in the last 3 years other than cleaning, door seals all look good. The chimney is kept fairly clean but not perfect. I have the owner's manual it it claims a max burn time of 9 hours. Will installing a insulated chimney liner transform my DW into a "new" stove? Am I just wasting my time and money if I purchase a new Quad? (I plan on installing a liner with the Quad)
Many people install their own liners, many have it done professionally. Depends on a lot of factors. Liner kits can be purchased online from a number of e-tailers, or locally if you have a dealer. Sounds like a 3' vertical run out of the top of the stove to a 90° elbow, then a 3' horizontal run to a thimble and then it just dumps into the masonry chimney with a 9" x 12" clay tile lined flue to daylight. Not optimum for woodstove performance. What's the total chimney height from stove to daylight? Is this stove sitting in front of what was an open masonry fireplace? Any chance you could shoot us a pic or two of the current setup? In any case, lining the flue would seem to me to be the first priority. You just might find, then, that the good ol' DW performs a whole lot better and you can take your time deciding about replacing it. If I'm mis-picturing the current setup, please correct me. Anything else connected to this same chimney structure? As I mentioned, pics would really help a lot if you're able to provide them. Rick
shilohfarmboy said:...Can I just use single wall vent pipe to line the chimney?...
