The more you can tell us about your current situation, house layout, where the stove might go, what you currently use for heat, and how much do you use, etc., the better advice you'll get.In the market to buy a newer pellet stove.
Can anyone recommend what might be a good -- low maintenance stove to purchase?
Needs to heat at least a 2500 sq. foot area.
Thanks very much.
I was in the same boat as you. Ended up going with an ashley 5660l. I love it. I was getting prices for stoves from 2500$ low to 5600$ high without install. I did hvac for 10 years prior so that helped my decision along. Could not justify those prices especially since I have a 97% efficiency furnace with a gas valve and blower motor that learn heating habits and adjust gas flow and blower motor speed automatic for efficiency. I got that furnace for 1000$ my pro price. If I installed it for a customer it woulda been around 4000$. So again I though the stove prices where insane for some of these stoves. Beautiful and proven stoves yes but I couldnt justify it in my mind. So I found the ashley at tractor supply. Thought it was a great looking stove for my home lay out . And it was a fair price. I pulled the trigger and couldnt be happier. Yes parts are definitely going to fail eventually maybe sooner or later than other stoves. Man made it so it has flaws and will fail eventually like any other machine around. Thats how I viewed my shopping experience and how I picked. But it comes down to your personal tastes and budget. But good luck whatever you decide your going to love the pellet stove world.
Fairly easy everthing is easy access. I clean it daily and it runs without a hiccup.how is the maintenance with this stove
If you've been happy with the St. Croix, why change brands ?????????? They still make new ones, work basically the same, especially if you do the routine stuff yourself, familiarity is a wonderful thing ........... plus, if ya keep the old one a lot of the parts make good spares ......................Thanks for the replies. We currently have an Afton Bay, St. Croix stove - about 12 years old - runs great - heats great - but I want to purchase a newer one after this season cause this thing always needs some kind of part, etc. Right now we are waiting for a control board to come in.
It heats up to 1800 sq. feet and does the job very well.
Someone we know got a new Harman pellet stove and loves it - very low maintenance.
So was just curious what you guys recommended.
We heat mostly with the pellet stove and very rarely use our furnace.
Thanks.
For your square footage I would recommend a P61 or a P68 if your trying to heat the hole house but if if your home is newer with good insulation,windows and doors you may get away with a lower BTU unitIn the market to buy a newer pellet stove.
Thanks very much.
Hey Tony, What kind of pellet consumption are you getting running the two stoves? So far this season and last year in tons? ThanksWe have 3000sqft with 2 floors like I mentioned above. II's cooler upstairs but we like it cold for sleeping. The P68 wasn't big enough as the back side of the downstairs just 2 cool at time. Had to run the 68 too warm to get temp on back to 65. Zoning was better in the long run. Also dropping the temp at night on very cold nights to try and save pellets was counterproductive as it took too long to get Temps back up. 2 stoves solved that as well. Shoulder season I rarely us the back on. 30-50 degree nights only use the 43 at night primarily and during the day as needed in room temp only as it is cooler. Sub 20 both run 24/7. P68 in stove temp mode and when it gets colder gas kicks in when needed to keep pipes from freezing.
