This is my first year w/a Heritage, and my first year with a woodstove in the house I'm in, but I've lived with several different woodstoves in the past, so have some context in which to evaluate this one. I'm heating a 2000sf house, and just to make life interesting, my boiler went down in January. Except for the night when the gyrfalcon had to talk me off the my-door-gasket-has-failed ledge, the house has been warm and cozy, and it's done a great job of making this the most comfortable winter we've had here. I have a sunroom full of plants that are still thriving in spite of the transom between the hearth room and the sunroom, and the 2 weeks+ of -20F and colder weather we've had. (I just went downstairs and found the hearthroom at 78 and the stovetop at 300. Someone--surely not my son who is sitting in front of the stove?--left the primary open . . . )
I'm burning poplar--nothing but poplar--it's seasoned, but it's been sitting stacked for several years, courtesy of PO. The wood on the tops and bottoms of the stacks were compromised by moisture, and I could absolutely tell the difference in terms of heat when I tried to burn the wet stuff. Finally came to the conclusion that this was an exercise in frustration, and now I toss that stuff aside to burn next fall after it's had a chance to dry out. I'm using about 2 cf of wood a day when the temp is around 0 to 10F (measured by monitoring my inside wood rack fillage and usage)--I figure 4 to 5 cords a winter, roughly.
She's a little particular, she is, not your-I-burn-anything-backyard-boiler-mail-order-bride type stove, but as long as I'm willing to use dry wood, and pay a little attention to the burn cycle, I could not ask for a better stove. And trust me, that stove puts out serious nap-on-the-couch rays. And as for the 24/7-rugged-almost-maintenance-free stuff? I empty ashes daily--about a quart or two--and give the glass a quick wipe because I like watching the fire through really clean glass. Personally, I don't mind that. That having been said, no boiler in January and February? You bet I'm keeping this going around the clock. I can't even imagine what this winter would be like without it. I'd have had to drain the plumbing and move out.
I put in a stack damper, and when I shut that partway, it drives more heat out into the room. It will absolutely drive me away from sitting in front of the glass if I've got a good fire in it and then shut the stack damper. I *never* go to bed with the primary open, or even cracked, yet it's keeping my upstairs almost as warm as the downstairs--maybe 2 degrees colder, which is fine, as our bedrooms are up there. I open the primary full tilt to do my `clearing its throat' burn once or twice a day, and other than that it's almost always on half-open to closed. I've learned how to lay a fire that will burn overnight or while I'm gone during the day. (Won't bore you with the details unless you want me to.) I rarely-to-never use the ashpan. I just brush the ashes to one side and the coals to another, and scoop the ashes out with a Rubbermaid dustpan and dump them into a turkey roaster that's inserted partway into the firebox, so that airborne ashes are swirled up in the updraft. I know that sounds like it's scooped straight from a `you know you're a redneck if . . . ' poster, but it's working for me. The better I get to know this stove, the better results I get out if it. It's everything I hoped for and more.
I've thought at times that it would have been nice to have gotten a Mansfield, just for those extended -40 stretches, but I hope to have the boiler back up and running pretty soon, and plan on burning that as a back-up (funny, that's what I used to say about a woodstove). I'm actually really confident that I got the perfect stove for my application. I don't mean this in a smug, ha-ha-this-works-for-me-what's-wrong-with-you way---just the opposite; hoping that you think, `okay, if it's working for her, I bet I can get similar results out of my bigger stove'. And not that I think it makes that much difference, because cold is cold wherever you go, but I live smack dab in the middle of Alaska, for what it's worth.
I hope that whatever stove you end up with, you can find as much satisfaction in living with a stove as I have, and as I believe most of your hearth-mates here have done.
Can This Relationship be Saved?
MF1529 said:
I have had a love hate relationship with my Mansfield and I have now decided that I am tired of dealing with it. . . .
I'm looking for a stove that will crank out some good heat. I also want it to be a rugged almost maintenace free that will stand up to 24/7 constant use. . . .
If you're not back in love by Monday, you can't say you didn't try.
But before you ship your Mansfield, just make sure you've let her fry.
Put some seasoned wood together, watch the secondaries play.
If you're not back in love by Monday, Ohio's just three states away.
