I am replacing my 40 year old Lopi with an Expedition ll. I got a $5000 voucher to replace it. I hope I am not making a mistake. I was hoping for more efficient wood burning
Thank youYou’ll be fine quadrafire makes good products. Shouldn’t have an issue with overnight burns with that either, firebox seems big enough.
Thank youJust know that a new stove will require dry wood, 40 years ago you could get away with subpar wood but your new stove will not work well with wet wood.
I think it is called a Lopi X. It is not flush. No blower. We are retired so we usually keep it going during the day. It usually goes out in the night but it is usually mild enough that that is no big deal. The house was built in 1975. I have put in dual pane windows and extra insulation in the attic.Which Lopi model is being replaced? Is it flush or does it project out onto the hearth?
How was the Lopi used, 24/7 winter heating or more occasionally, such as mostly nights and weekends?
Is this in a new home construction or older home?
Got it. I downloaded the pdf after posting. The list has not been updated since February, so really this is your only option. The rest are obscure models and CARB has not gotten around to testing the bulk of Fairbanks, AK-certified woodstoves.E/W is the direction I load. I don’t know how tall the chimney is but I will be sure to press them on that when it is installed.
the EPA 2020 certification isn‘t enough to qualify for this voucher from the Butte County Air Management District. I am starting to think this is more trouble than it is worth.
Yes, there's about 5 or 6 speeds, none of them move a bunch of air and most of them are loud.Can the blower speed be manually controlled on this model?
That is not goodYes, there's about 5 or 6 speeds, none of them move a bunch of air and most of them are loud.
Honestly I'm probably just picky. It's one of the things of an insert you can't get around, they will all be like this. They can only fit tiny little fans in there, so it is what it is.That is not good
It'll heat 1100 sq ft just fineDoes anyone out there use their Expedition ll as a primary heat source in an 1100 square foot home. The salesman keeps telling me this insert is not for 100% of your heating. I am home all day and not concerned about reloading
Thank you. My salesman just left because he was nice enough to come up and talk me back from the ledge about this insertIt'll heat 1100 sq ft just fine
