When I installed my VC Montpelier insert I pulled 6"flexible SS liner down my internal masonry chimney. The old flue was 8x12 clay pipe. The top 5 feet of the chimney is above the roof line so I filled the gap between the liner and the clay pipe with Roxul for the top 5 feet. My hope was that this would keep the liner warm and prevent any excess creosote or condensation there.
For the top of the clay pipe I made a SS cap that I sealed to the clay to prevent any warm air from working its way up the old flue.
I just finished a sweep and got about a quart of fine black powder from the 15 feet of liner.
My question is should I seal the bottom end also? I've seen a number of discussions on block off plates and Roxul at the old damper frame. If the top is well sealed will there be much gain from sealing the bottom also?
Thanx for your help and advice...
KaptJaq
KaptJaq
