Selkirk Supervent Class A ?
Todd 2
418
NE Ohio
Found some end of season deals on class A Selkirk Supervent SS inside and out.
$690 for a new 11ft complete kit close out deal. Hard to pass on from everything I've priced.
What do you think, Quality, great or average ?
If you are using it, tell me about it.
I thought I would go for something like ICC or Ventus for safest possible but for the $ the Supervent seems to make the grade. Thanks !
Todd
11ft is too short so you will need to add pipe. Price compare the components at www.dynamitebuys.com
Reactions: Todd 2
Whoops, should have added that 5 feet + of double wall stove pipe will be below it for a total of 16' +
that will be 3 ft taller than the roof peak. The stove pipe will be extra.
Thanks for the compare site, missed that one.
Todd, there is a place out in Washington that has ICC pipe on sale, 10% off. The 4 foot adjustable stovepipe was well under 200, so I wouldn't expect the chimney pipe plus extras needed would run much more than $700...worth a look. ICC is great pipe, provides great security and peace of mind. Lifetime warranty on ultrablack stovepipe and Excel chimney.
Reactions: Todd 2
I've got two installs with Selkirk Supervent (from Menards) and have no complaints. Would purchase again. Seal the vertical exterior seam with silicon because rainwater can follow that in.
Todd, I got my stove pipe adapter, ceiling support box, attic shield, 10' of Class A, and cap (didn't need the flashing), for about $400 at Menards. Selkirk.
Reactions: Todd 2
Would you happen to remember the sight ? that sounds reasonable. Thanks
Todd
I've installed and used Supervent in two houses, no problems. I also siliconed the seams, just as a precaution.
Todd
Just looked it up , Todd:
stoves-pipes.com , 1-888-850-9663
Free shipping over $99 order, 10% off ICC ultrablack and excel. All pieces are clearly listed, proces above each piece.
Hope this is helpful.
