Thanks again for the great post https://www.hearth.com/econtent/index.php/forums/viewthread/19086/
Question about the "Theory of Operation" when "Heating from storage"
If the load circulator is on and both boiler circulators are off, why is there only flow through storage and not through either boiler?
If the shortest path for the water was through one of the boilers, then wouldn't the flow be through that path?
I thought when circulators are off (even IFC) that the impeller spins freely in the installed direction of flow.
So, if the storage path was longer (say installed next to the wood boiler in an out building) than the oil boiler path (say installed in basement next to zone manifolds) then when the load circulator only is on wouldn't most of the flow be through the wood boiler?
I am trying to do something similar with unpressurized storage and it seems that a zone valve on the return loop between the storage and the oil boiler that was closed when both boilers were off would prevent any "path of least resistance flow" when heating just from storage.
Somewhat confused???
Steve
Steve
