Spark Arresting Screen
thewoodlands
16,702
In The Woods
I'm checking these tonight on the 310 & 390, what is the best way I can clean them if needed?
Zap
You pulling the muffler?
Highly recommended a t27 T-handle to remove. After putting it back on get the saws hot and tighten them down again.
zapny said:
smokinjay said:
zapny said:
Na, just the cover for the spark arresting screen. Page 43
http://www.stihlusa.com/stihl_ownersmanuals/MS290_310_390_Manual.pdf
Zap
Brake dust cleaner would be quick be careful with that, or Air compressor small wire brush.
Not offten
Thanks Smokin, I'll go with the small wire brush and air compressor. How often do you check yours?
Zap
you can kinda tell you your starting to lose power a little and you start seeing a little more smoke than normal.
smokinjay said:
zapny said:
Zap
Not offten
Zap
Smokin here are two pictures right after I snapped the bolt off and before I cleaned it. Never took the after picture.
Zap
zapny said:
smokinjay said:
zapny said:
Zap
Not offten
Zap
Zap
Not enough to choke it but as you can see that air flow had to be slow down some what. Very fine screen I might add.
smokinjay said:
zapny said:
Zap
Not offten
Zap
Zap
That is the original screen, bought the 310 in the summer of 2008 and this is the first time checking the screen.
Zap
If you are not cutting in a govt forest where spark arresters are required, just remove them. I've been around power equipment for 50years that did not have them in place and have never seen any fires started because if it. I know a number of folks that remove them the day they get the tool. Just my $0.02
Tom
:lol:
Tom
I put one in my ported 460....Only an issue in dry conditions but dont want to be the guy who started the fire! just my .000002.
