    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. Salty Minister of Fire
    Central Ma
    So I seem to be replacing these about every 2 years, has anyone found a more substantial replacement? This next one will be my 3rd burnpot since 2008
    I spose I should be wicked happy I'm able to bend steel with my pellet fires. That means the stove is running well, just not thrilled about spending money on something like this all the time.
    #1
    Helpful Sponsor Ads!
  2. oldmountvernon Minister of Fire
    SE Mass
    at least now we know why you went from burning pellets to Fines, bits and chunks
  3. jtakeman Minister of Fire
    Northwestern CT.
    Salty are you burning your stove full tilt once it gets cold?
  4. Hellfire Member
    Sunbury , PA 17801
    Upload some photos of the burn-pot .
    The only thing i have replaced in my York that many times was the ash rod from the heat & corrosion.(carbon steel)
    Now i use 316 S/S rod the last 2 seasons without any degradation. (I use my york exclusively for heating not as a supplement)
    Are you using corn in the mix?
    I know i could build one out of carbon steel but the question is at what price would it cost for better high heat corrosion resistance steel and what grade would I use the nickel -chromium base or cobalt base as that can get expensive for just longer term durability.
  5. chuck p Member
    Pittston Pa.
    December 16 will be 6yrs still going on the same burn pot.It's starting to show some wear on the top and a small crack were the ignighter is.
  6. Hellfire Member
    Sunbury , PA 17801
    Ditto on mine too although i mig welded the corners in 2007 as i didn`t like the way the OEM welded it.
  7. SmokeyTheBear Minister of Fire
    Standish, ME
    I think one look no further than at what he has been burning.
  8. IHATEPROPANE Minister of Fire
    Southern,MA
    Yep...could be the Infernos...they clinkered and warped my original pot.
  9. Hellfire Member
    Sunbury , PA 17801
    What`s in them magnesium?
  10. SmokeyTheBear Minister of Fire
    Standish, ME
    Well I don't know it could be left overs from various .......
    IHATEPROPANE what color did your pot glow?
  11. oldmountvernon Minister of Fire
    SE Mass
    everything, think building demolition. yup guy yesterday said even seen asbestos
  12. Hellfire Member
    Sunbury , PA 17801
    Maybe the pellets are made from trees from the remnants of Chernobyl;ex
  13. Hellfire Member
    Sunbury , PA 17801
    I`ll stay w/stove chow never a problem except the dust .
  14. SmokeyTheBear Minister of Fire
    Standish, ME
  15. IHATEPROPANE Minister of Fire
    Southern,MA
    All I remember is a pile orange....when the stove cooled there was a large clinker and a warped pot.
  16. IHATEPROPANE Minister of Fire
    Southern,MA
    I find it hard to believe this day and age that would be happening. If it is true they would be shut down.
  17. oldmountvernon Minister of Fire
    SE Mass
    like i said, he said it, not me
  18. IHATEPROPANE Minister of Fire
    Southern,MA
    I hear ya, hopefully he was joking.
  19. Hellfire Member
    Sunbury , PA 17801
    What about the burn grate (seperate piece) does that burn up too?
  20. imacman Minister of Fire
    I'm assuming the burn pots are steel? Why not get it over with and have a local metal shop tig weld one up from stainless steel?
  21. krooser Minister of Fire
    The pots are steel with lots of 1/8" holes..
    The pot in my Pepin is the original from 1999 (?) but has some steel missing from the area just above versa-grate. I just found that the set screw that allows the driveshaft for the versa-grate to rotate is loose... I think that's why the steel burned out as the versa-grate was not working and i got a big, hot clinker right under the burn pot.
  22. magsf11 Feeling the Heat
    buffalo ny
    mine is starting to show 2 very small cracks but is still the same one that came with the stove.
  23. Salty Minister of Fire
    Central Ma
    Sorry been out all day. Previous pots have always cracked around the igniter area then gotten worse. After they crack all the way the thing usually warps out bad.
    This current burn pot is just plain warped from heat. The piece that sticks up in front of the flame is totally toasted. It's got 4-5 waves right across it and it's double thick there too. The whole burn pot is warped enough now that it's hard to get it in and out of the stove to clean it.
    I'll take a pic of this the next time I clean it.
    This used to get run wide open in the winter, last year it spent most of it's time on 4 which is still a very healthy/hot flame.
    Have not had issues with the bottom versa grate. Just the burn pot surround.
    I figured someone may have found a solution by now. Seriously doubt I'm burning asbestos. I think the guy was full of crap. Do you know how bad the penalty is for abating asbestos without a permit or releasing into a waste stream in Mass? YIKES man.
  24. woodsman23 Minister of Fire
    mine in the afton bay is also in rough shape.
  25. heat seeker Minister of Fire
    Northern CT
    On my 3rd season with my used Afton Bay. It had a new pot when I got it, and a used Versa-Grate. Both are in the same condition as when I got it, burned about 6 tons, mostly on level 4. Occasionally I use level 5, and if it's warmer out, level 3.
