Hey all,
I am beginning to get concerned about how hot the wall behind my stove is getting. I've got 45" up from the floor that is ceramic tile over poured concrete, and then stud wall with drywall the rest of the way up (total ceiling of about 7'6"). The tile stays quite cool, but the drywall gets almost too hot to touch. I'm sure it's the heat radiating from the black pipe causing it, but I've got 14" of clearance from the pipe to the wall. The pipe is ICC double-wall, so according to the manual: http://www.icc-rsf.com/Manuel_catalogue/UBII_ang_2006-04.pdf (my install is exactly like the "90 degree elbow" install on page 6),
...I have over double the safe clearance, right? I know the "too hot to touch" thing is very objective, but I don't have a way to check the temp exactly.
At what temp (I'm going to buy an IR temp gun) should I start to worry? How hot can drywall get before it lights off?
The room with the stove running about half-throttle, stays 80-85 degrees, and the heat moves around the house nicely, but it's getting harder to sleep at night thinking about this...
Any advice would be appreciated.
Thanks,
-jason
Thanks,
-jason
