I am looking to install double wall stove pipe through a block basement wall to attach to a double walled chimney. Do I need to use a thimble to properly do that since the block is not combustible? Any advice or suggestions would be useful. Thanks
I had my Manny professionally installed. Through the block with a thimble. My wall is finished on the inside with drywall so that may change things, but, to support the weight of the chimney, I would think a proper thimble would be required.
Any other ideas about my question. I have found this and am wondering if this will work instead of the thimble. http://dynamitebuys.com/store/cart.php?m=product_detail&p=6652 I was also wondering if just using a 12 inch section of double wall chimeny pipe would work. thanks for any help.
I read somewhere that the triple wall is supposed to extend into the living area 3".. This is for pre-fab chimney not sure about hooking up to an existing flue..
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
