I recently installed a Sierra 2100HS in the fireplace of my new home. I'm used to burning with a smaller non catalytic stove (Englander) similar in style to the Sierra but smaller. I ran a SS liner up the chimney and mounted the stove on my hearth. I think I have too much draft since I can hear a good amount of air coming down the chimney before it's lit. Once lit it will burn up around 800 degree with the damper fully closed until it burns down a bit then will run at about 600 for a few hours. Additionally, I don't feel like it is heating as well as it should for the size of the stove. I have not installed a damper block off plate but I did seal the top of the fireplace chimney (probably not air tight). My questions are: Should i do something to reduce draft? I.E. flue damper or reduce liner size to 5". Will the damper block off help with heat loss?
Here is the link to the stove I'm using:
http://sierraproductsinc.net/woodstoves.htm
