There is a sticky at the top of the forums with a number of previous discussions regarding this topic:
Start HERE if you are New to Burning / have a draft problem / stove's air is restricted / FAQ about
https://www.hearth.com/talk/threads...lem-stoves-air-is-restricted-faq-about.59225/
In general it can depend on the wood, but for the more common wood types ash can be as soon as 1 year, oak and locust can be 2-3 years. And this is only for wood that is cut up, split up, and stacked up (aka CSS or C/S/S)
No, it never does stop. We're talking about the seasoning of Red Oak, right?OMG does it ever stop?
friend who had been cutting down some old olive trees insisted on carrying logs up to my living room and putting some in my stove. They were wet as in very and left little puddles of water across my living room. Some even had leaves attached!
Olive is a fairly dense wood, correct? Nevertheless, if you have a lot of hot, dry weather (which I think you do there,) two years should do the trick on any stack of splits. [Hmmm, my sister lived there for a while....you would think I would at least know what the weather was like.]I took all the logs which had been given to me down to my wood yard and left them with the others designated for burning in two year's time.
Yes, summers are very hot and usually very dry. Olive is a hard wood and gives out great heat. Fortunately winter is short here and already spring flowers are carpeting the olive groves with a lovely show of colour. Heat is needed really only for the evenings now but it is so nice to watch the stove that I have lit mine today even though without heat the temp inside the house was 19 degrees celsius. Now 22 celsius now the stove has been lit for around an hour.No, it never does stop. We're talking about the seasoning of Red Oak, right?
The good thing is there are new wood burners popping up every day.....OMG does it ever stop?
I underatand all new epa stoves require seasoned wood. My question is how long myst you season before its acceptable. Obviously longer is better but...
I agree with all of this, except that locust does not take as long to season as oak. I have found one year is generally all that is needed for locust.
I wonder what percentage of people actually utilize a moisture meter or just season to a time frame....
