Things are really burning here! I'm finally getting the hang of things. I've posted this before but this time it's true. I've been watching the fire instead of the thermos to set the stove. Let's say I'm very pleased with the results. I'm getting it to cruise around 550, 600 or so peak on pretty full loads with great burn times for the stoves size and type of wood. 5 almost 6 six hours on maple. Now it's not producing heat that whole time but can easily be restarted without kindling.
Here's a quick run down of my stove operation:
Reload temp 350-400 with the air closed from the last load. Outside temp today was around 28-32F. 18ft of pipe straight up.
I rake the coals forward then push the ones in the middle in front of the dog house to the back of the stove creating a small trench for the some air. This bit of hot coals helps the split in the back to burn fully through.
Loading E/W 1 medium to large split in the back, 1 medium split in the front bottom, 1 medium to smaller split back/top, 1 smaller softer split top/front.
I leave the door open a crack until the single wall pipe thermo reaches 300 then shut the door. In few minutes the pipe temp will start to climb it's now I'm watching the fire. I can close the air half way, within minutes I close it in half again. This makes a noticeable change to the fire pattern. I then wait till the fire begins to strengthen in intensity and close it about 1/4 more. Now I go back to the stove top thermo and it slowly rises to 525 and I close it a touch more and at 550 (about 10-15min) one more nudge and thats it. At this point the air is open about 1/4- 3/8" if I want to really stretch it out I will close it again in about 45min and she'll peak around 600 stove top if I don't she peak around 650* The pipe temps drop to around 250-300.
With a good coal base and the fact that the stove is smaller and the wood is good and dry, this whole process is taking me around 30min.
With this method I now have a fire of two medium splits of pine and 1 large split of crappenwood (Cottonwood) that's been cruising at 550 for over an hour. Base on the type of fuel to me that's great. This small load is because I loaded it at 9pm and want to reload around 1230-1am before bed.
Well that's my story, right or wrong the glass is clean, house is warm and I'm not getting up every ten minutes to check to fire.
