Tree ID
billfred
Burning Hunk
Jul 28, 2015
177
indy
Southeast Michigan
Great. Based on the leaves and what I googled, might be slippery elm.
Pics of leaves and bark looks like mulberry, and I think I can see unripened fruit in center right of first pic.
Reactions: JSeery and JimBear
Venation on elm (including U rubra) is tighter and more uniform. http://dendro.cnre.vt.edu/dendrology/syllabus/factsheet.cfm?ID=42
And leaf margin is doubly serrate.
Surface of slippery elm leaf is scabrous (sandpaper). http://forestry.sfasu.edu/faculty/s...-916/photographs/105-ulmus-rubra-slippery-elm
Mulberry is typically a dioecious species (male and female on different trees). http://dendro.cnre.vt.edu/dendrology/syllabus/factsheet.cfm?ID=527
Sometimes mulberry leaves are lobed, but often not. Leaves have single serration.
Can you take a close-up of the center right area of pic #1.
Leaves and bark look like an Elm, however I wonder about the multiple trunks coming from the base. I have about 6 in my back woods and many in the area and none of them look like that. All have a single trunk with large canopy at the top.
Actually there is little berries. I guess it might be mulberry.
It sure looks like mulberry bark & leaves. Those defiantly unripened mulberry’s. You’ll like it, it burns well & splits a lot better than elm.
In my limited experience American Elm will/can have multiple trunks or branch off very low, Red Elm is usually a single trunk & not fork off till farther up the tree.
You are spot on...Mulberry.
Never looked it up before, but mulberry has a janka hardness of 1680 and the btu's per cord is super good, between oak and hickory.
