New stove suggestions
Brian1971
55
Pa
I'm currently burning an older englander add- on furnace and would like to upgrade next year. It makes decent heat , burn times aren't the greatest. Of course heating from the basement , ranch house 2500 sq. Ft including the basement . Masonry chimney which I plan to upgrade with insulated liner . Any ideas ? Thanks
Looking for a stove?
2018 drolet ht2000
So are you wanting to rear-vent back through the fireplace opening, or would you go straight up with top-vent stove, then 90* into the chimney?
I just purchased a Jotul. I have yet to put it in, but the Jotul model F50 TL or F55 would probably heat your house well. I was going to get one of those but decided they would cook me out of the living room where my stove is. I went with the F500. The 50 and 55 say they have burn times of 8 plus hours on the 50 and 10 plus hours on the 55. Mayhe something to look into. I'm not expert, I have just done alot of research lately and everyone seems to love Jotul
Thanks I'll look into those
Reactions: 11ultra103
I’ll second that
The Englander 30-NC and big Drolets are the best values in 3+ cu ft stoves.
Reactions: moresnow
Are your basement walls finished/insulated?
Thanks I've been looking at the Drolets , I like the legend ll . Also looking at Woodstock ideal steel, I'd have to get the plain version .i know that's comparing 2 totally different stoves, I'm just looking for 10-12 hour burn time with an easy re-lite
Keep your old stove. The new burn times are marketing. They are from full start to cold coals. You will save a bit more wood, and have less creosote. But our experience so for these new stoves throw less heat and need more attention.
Thank T-Roy . How's the burn times ?
I’ll get 10 hr. Burns with oak pretty easily. Depends on your definition of “ burn time”. If loaded full I re-load every 10.
I loaded my stove at 8 last night that has been 20 hrs 6 hours into the burn I got up put 2 splits on didn't adjust air are anything and 20 hrs later air wide open all day still have this
2018 drolet ht2000
Reactions: Warrenc123
