Some of my chains specify a 10° angle on the side plate when sharpening. It's a real pain in the ass keeping track, and holding the angle. My bench grinder does not have this adjustment.
If I just ignored the 10° spec when sharpening the ones that are spec'd for that, and went at a right angle to the bar, how much do I give up?
Some additional background:
I ordered 2 similar Woodland Pro chains from Baileys last year, they both say Carlton on the links. One is chisel, the other semi- chisel. The semi- chisel one does not specify the 10° offset, the chisel one does. I can only ID which is which by holding them right next to each other and comparing.
Next are two identical Oregon vanguards. Chisel, 10° side plate spec, and those bent over rakers. Not awesome.
I also have two identical Stihl chains for the saw. Both are Chisel and no 10° side plate spec. These are my favorite of the group, but were expensive. I found a pipe with the first one within 30 minutes of putting it on, and cracked a cutter link. I rocked the second cutting a log that was too big for me to lift off the ground.
