Hi everyone, me and my wife just purchased a new house with a wood burning stove. I am not sure on how old it is or the model, the doors say fisher on the front and there is two knobs one on each door for the air intake. I tried using it for the first time last night and didn't work out so well. I couldn't seem to keep the fire going. I did some research on flue tempatures and I got myself a magnetic thermometer to put on the single pipe wall pipe, my chimney sweep suggested I keep the tempatures in the burn zone of 300-600 degrees. I couldn't seem to get the tempature up any higher than 200 degrees, I had the thermometer about 6" above the surface of the stove where the thermometer manufacture recommended. I seemed to never get any of the bigger logs to light and it would smolder out in about 20 minutes. I would have the air knobs completely opened with the doors shut. I started with just kindlen and fire starter logs and then put my bigger split logs in after it started going. Should I start the fire with bigger logs inside the stove? Should I be leaving the door cracked open till I get the proper flue temp? How long should the fire be burning till I see proper flue temp? Should I also have a thermometer on the stove top surface itself? Also how often should I be taking the ash out of the bottom of the stove? Basically I need any tips I can get cause I am totally new to this and am lost at this point. Thank you in advance for any advise
![[Hearth.com] 100% new to woodstoves [Hearth.com] 100% new to woodstoves](https://www.hearth.com/talk/data/attachments/165/165784-38413a7a01b4977d742f8e748392372f.jpg?hash=F0Y3VwdsZB)
![[Hearth.com] 100% new to woodstoves [Hearth.com] 100% new to woodstoves](https://www.hearth.com/talk/data/attachments/165/165785-0a1c8bbeb749bfeaccaf7e2f35b11a02.jpg?hash=z9Z0RA-Ziz)
![[Hearth.com] 100% new to woodstoves [Hearth.com] 100% new to woodstoves](https://www.hearth.com/talk/data/attachments/165/165786-ceac77077947f3ebb25364481874d11e.jpg?hash=oP-CUlOyfa)
![[Hearth.com] 100% new to woodstoves [Hearth.com] 100% new to woodstoves](https://www.hearth.com/talk/data/attachments/165/165787-5f65ec15fcd1c5288af2b0e611888c07.jpg?hash=n1ZoiT9YvM)
