Ashful
Lots of questions in that rant, so I numbered them.1. Should I be seeing flames when running my ashford at about the 4 o'clock position? I'm not seeing any. If I turn it all the way to 6 o'clock I get flames.
2. Also can someone explain how the thermostat works.
3. When it was warmer out in would hear the flap close around 3 o'clock now that it's colder out I hear it close around 5. Is that normal?
4. If the flap closes at say 4 o'clock and I set thermostat at 3 o'clock will the thermostat open back up when needed?
1. You may or may not see flames, depending on outside temperature and chimney height. I suspect you may need to run a hair higher than 4 o'clock, on most installs, to see flames.
2. Thermostat is a simple bimetallic coil spring (think continuous clock spring) wound on a shaft, to which the air inlet damper is connected. When this spring cools, it opens the damper a bit. When it gets hot, it closes it a bit. In this way, for settings around the "NORMAL" range, the damper will act to automatically modulate intake air and maintain constant burn as load burns down. Of course, if they removed the "NORMAL RANGE" indication from the new swoosh label, so... good luck.
3. The clocking of the flap closure is dependent on temperature of your stove, and how fast you're running the fans, and has nothing to do with outside temperature. If you're running the stove hotter and fuller, because it's colder out, then your described behavior might make sense. Flap will close at a higher o'clock position when the stove is hotter.
4. Yes, that's the idea. However, if you go way past the point where the flap closes, there may not be enough travel in the spring to get it open. It's a limited travel mechanism.
		 It is calibrated for each model as well. I have learned this the hard way
		![[Hearth.com] 2015-2016 Blaze King Performance thread (Everything BK) [Hearth.com] 2015-2016 Blaze King Performance thread (Everything BK)](https://www.hearth.com/talk/data/attachments/169/169984-48a5ec5f56035e8b1f015ed145405384.jpg?hash=ROEARAhuHB)
		![[Hearth.com] 2015-2016 Blaze King Performance thread (Everything BK)](/talk/data/attachments/170/170164-80cedbc839e65a30d6a07f29694c3c9d.jpg?hash=q7_DZz1xxz)
