jetsam
Just wanted to report back how the new BK Princess insert is doing after 8 days.
Got the door installed a week ago yesterday. Adjusted the latch and ran the dollar bill test until it was right. Will have to readjust at some point as the door seems to be settling in to the door gasket. Started the first fire with the small load as mentioned in the manual then a bigger one after that. Anticipated bad smell from the paint curing and it did smell but not anything like I was expecting. Opened a door for about 15 minutes then closed it and fired up the ozone machine and that took care of it after a while.
This is sure different in all aspects compared to the old insert we took out. All the wasted heat(slammer install), wood usage(figured one split per hour), and ash clean out(sometimes pulling out almost two 5 gallon buckets full) are gone now. It's like going from a Model T to a new Corvette or so it seems. Only thing the same is they burn wood inside both of them.
So I have some comments/observations/questions.
1. Getting the cat up to temp seems easy to do and not much time(to me) to get there.
2. It is crazy how long a few pieces of wood burn and put out usable heat.
3. Have been burning 24/7 since 3/25 and pulled out less than half of a three gallon bucket of ash.
4. My CSS wood is marginal as I've said and both lower bottom corners of the glass get pretty black about 5" up and across the bottom. Cleaned it once so far with some ash on a damp paper towel.
5. We have NEVER had so many blue flames!! It's all the time, right now it's solid blue flame off the back of the wood in back of the firebox. Can count on one hand probably how many times we had blue flames in the old insert.
6. Bought some Eco Bricks(6 to a pack) at TSC on the way home from picking up the PI. I raked the coals forward about halfway to load the Eco Bricks. Wasn't sure how many to run the first time so loaded 6 N/S against the back wall and pushed the ashes back to the front of the Eco Bricks. Put small(3"-4") Ash rounds N/S for overnight. Set it a little below half on the tstat, fan on high. 8:00 the next morning the Ash was gone but the Eco Bricks were still glowing red across the back wall. Went to reload and the Eco Bricks were solid as when they were put in. Loaded 7 on top of the first row of bricks and threw in almost two 5 gallon buckets of splits cut to length(16", old insert would do almost 24"). They ranged in size from 2" to 6". Ran all day like this a little above half on tstat. Time to reload that evening and the very bottom row of Eco Bricks were mostly solid with the upper row fairly burned up but still some 4-5" solid chunks left. Nuts....
7. Never thought this would heat our house but be a good supplement. So no expectations of being let down next winter.
8. Getting great secondaries which are cool to watch, probably on about each load for different lengths of time. Maybe saw those twice in the old insert.
9. STT are from 300*-700*+ throughout the burn cycle. Best I ever got comfortably on the old insert was upper 200's.
10. Going to have to come up with a new air circulation plan for the house with this insert. The old insert had 580 cfm of air output and this one seems to be about half that. Old one had the air outlet probably 6" farther into to the room and deflected downward, new one is basically going straight up the brick face of the chimney. It makes the upstairs about 6*-10* warmer and a couple of places on the main floor that much cooler. Living room ceiling is peaked and 20-21' tall with two ceiling fans that run 24/7/365. One is going down and the other is going upwards currently.
First question:
1. Ran N/S load the first few times then ran E/W. Seems to be E/W lasts longer? Or is that my imagination? Assuming it blocks the air flow in that orientation.
2. After cat thermometer gets into the active zone how long does it take to clean up the smoke out of the chimney?
3. Ran 4 pieces of DF 2"X8"X10" across the back wall E/W stacked on top of each other like a solid block. Burned for 6 hours before I reloaded, set on a low setting putting out decent heat and still barely active cat before reloading. The cat temp was half way into the active zone but still could see some faint smoke out the chimney. It was too warm to be steam, upper 40's. Should the cat eat all the smoke?
4. I loaded 12 Eco Bricks on bed of coals, N/S along the back wall 2 rows high. Got it up to temp and set the tstat to high, fan on high and watched it for an hour or more to check the STT. Climbed up to the upper 700's (IR gun). Cut the tstat back about 2 dots and I could hear the little air door hit the bottom. It must have been heading closed from the temps I'm guessing. What's too high a temp for STT?
5. The manual says run the fan on low for a low tstat setting and high for a high tstat setting and so on. I've been running the fan on high for about everything, cat still in active zone always. I want it to strip off as much heat as it can if I need the heat even if the tstat is on a lower setting. Any issues with doing that?
Well that should do it for now sorry about the length, lots to learn with this new insert. We feel it was money well spent considering how old the other one was and being unsafe. Thanks to all of you who told me it was unsafe...we were just cruising along not knowing any better, so thanks.
Steve
1) Probably your imagination. I've never noticed a significant difference, and the stove burns front to back no matter how you load it.
2) Sometimes right away, sometimes not until the wood finishes offgasing? Depends what you're burning, how wet it is, and how hot the stove is.
3) It doesn't always, see above.
4) If your gaskets are in good order and you're burning normal fuel (no loads of kerosene soaked wood chips), you don't have to worry about stovetops. I've never seen 800 on mine, but I've never burned anything but wood in it. 800 with fans on high would worry me considerably.
5) You'll have false readings on your cat probe thermometer (it'll look lower than it is). Also your shoulder season burn times will be greatly impacted. The thermostat is going to open up the air to make up for all that heat you are blowing out. Check often to see how your creosote accumulation is going at the top of the flue.
[/QUO![[Hearth.com] 2018-19 Blaze King Performance Thread Part 2 (Everything BK) [Hearth.com] 2018-19 Blaze King Performance Thread Part 2 (Everything BK)](https://www.hearth.com/talk/data/attachments/243/243767-db98241438ad1eecb39554c374f252cf.jpg?hash=EnkrIhXw0-)
