3 stoves going.....
bugsy
28
ohio
Buck 91, wonderwoood , and king pellet stove on low to heat this 2 story farmhouse , 20 in day, singles at night, cat went out first year on the buck , been burning without cat last 2 years , didnt seem it helped much with heat output , maybe just cleaner chimney , having 3 different people run the stove didn't help the life of the cat, starting to wish I had a boiler.
Have you done anything to try and get more from the Buck? Assuming it at least has a liner, I'd get the cat replaced and put in a block off plate if you don't have one.
I found that with the cat, I could run low, maybe a little flame in the box, but the cat would be blazing on the smoke and I couldn't hold my hand in front of the blower outlet for more than a couple seconds. When cruising the stove, I had the shotgun air (left slider) closed and the right slider pulled out maybe1/8-1/4". You should get more heat out of each load that way. The slower the air is moving through the stove, the more heat it can extract from the exhaust.
And yeah, the chimney didn't get very dirty with the cat working. I miss that stove. :(
My problem was, I didn't have enough control over the air, and cat temp would be pushing 1800. The cat won't last long when you run 'em that hot. I liked to see between 1100 and 1500 on that cat probe dial.
One problem was air leaking at the ash pan gasket. You can tell that's happening when the coals over the ash dump lid are glowing more brightly than the other coals in that area. I had to re-do the gasket to make sure it hit the ash pan housing squarely, and that there was no gap where the ends of the gasket came together.
The other source of too much air was that the plates on the right-side air control slider weren't sealing off the openings tightly. Another Buck 91 user had the idea of removing the plates from the rod, taking the rod out, and bowing it up slightly in the center, so that it holds the plates closer to the openings. I heard that idea too late for my time with the stove. But I did put some shims in the rod holders, which raised the plates closer to the holes.
Now, if you get the plates sealing off the holes better, there's a risk that you might crash the cat if you cut the air too far. You need to know what you are doing to run the stove well..took me a while to figure it out.
[Hearth.com] 3 stoves going..... [Hearth.com] 3 stoves going..... [Hearth.com] 3 stoves going.....
I was trying to heat my MIL's house with the stove not centrally located, 9.5' ceilings, and no wall insulation. I had the second story blocked off with a curtain across the doorway.
Sounds like you may need a wood furnace or boiler in that place, though..
I think I'm going to try to replace the cat , unfortunately my wood supply is not the best 2 to 3 yrs old but covered in snow at the moment , have enough dry in garage for a few more days.
If it's been split and stacked for a couple years and top-covered, it should be pretty good.
If it is now covered in snow I would assume it was not top covered
Most is split , was stacked , most of stack is fallen over and no cover. I do have stainless liner in chimney.
I like to have my wood for the year covered a couple months before I'm going to start burning, so it has a chance to dry any moisture from rain off of it. Stacking it near the stove for a week or so will help as well.
